Old 08-12-2009, 09:38 PM
tmbg is on a distinguished road
mini-router build
Hi folks,
I've started building a mini-router of my own design, somewhat inspired from some other machines I've seen on here (ok, very heavily inspired by).
I have the Z axis mostly built. Only thing I'm lacking so far is having the linear rails screwed down to the supports. They're a MAJOR pain to drill and tap! I got a carbide spotting drill in the mail today, and I can successfully drill them, but I've only managed to tap one hole, but broken four taps. Not a good ratio so far.
Here's a video of my Z axis, driven by a cordless drill:
Old 08-12-2009, 10:05 PM
FandZ's Avatar
FandZ is on a distinguished road
Originally Posted by tmbg View Post
Hi folks,
YouTube - Cnc mini router z axis test
I'm looking forward to this build. Everyone goes bigger and better, would be nice to see a mini cnc machine.
I'm guessing that was about 3 inches of travel on your Z. What will be your tables working area? Also what do you plan to use for a spindle?
Old 08-12-2009, 10:15 PM
It's 3.5" travel for Z. I happen to have a piece of 1/2" 6061 which is 12x11-3/4", so I'm designing the table around that. Travel will probably be a couple inches shy; if I can get 9x9 out of it I'll be happy. The gantry is already machined, and it's 12" long. The Z Axis body is 2.25", so Y travel ought to be about 9.75". X may be a bit shorter, depending on how big the X slide block ends up.
I have one of the cheap ebay 56,000rpm air spindles that I'll probably use right away, but down the road I am thinking about making a simple little spindle similar to what's on buildyouridea.com, and maybe using an RC brushless motor to drive it. They're small, light, POWERFUL, and easy to speed-control.
I intend to build bigger machines when this one is done. I am acquiring ballscrews and linear slides/bearings for a maybe 2'x3' machine, and I'd really like to build myself a plasma table.
Old 08-14-2009, 11:21 PM
since I've been having problems with the stupid rails, I decided to go ahead and finalize the design on the table and base and start machining.
Also, I got my hobbycnc kit, got the driver built, and have mach3 setup and running the motors. Now I just need to get something that I can attach a motor to and watch the happy.
Here's some pics of building the base and table. The table has 9 1/4" T-slots. They were a big pain to machine; I had to run around 1.2ipm or the cutter teeth would just load up solid with galled aluminum. The table's counterbored for 5 10-32 cap screws per side, and the bearing blocks are tapped accordingly.
Edit: Hah, I have no idea how one of those pictures ended up upside down. Crane your neck and use your imagination
ID:	86591   Click image for larger version
ID:	86592   Click image for larger version
ID:	86593   Click image for larger version
Old 08-15-2009, 01:05 AM
FandZ's Avatar
Robust.. Looks great. 1.2inches per minute must have felt like an eternity but it came out great. Can't wait till I have a machine I can mill some metal with.
Old 08-15-2009, 05:11 PM
got the rails cut, leadscrew turned down and installed.
I managed to break a tap off in one of the holes, and break a screw in another. I'm on a roll today. I'll probably have to remake one of the bearing blocks
ID:	86643   Click image for larger version
Old 08-16-2009, 02:45 PM
Here's my approach to motor standoffs.
I hate turning very small diameters in the lathe, I always manage to screw it up. This was what I came up with to avoid buying standoffs.
I may end up rotating them 90 degrees so that it acts as something of a swarf shield.
Old 08-18-2009, 10:17 PM
Y and Z axes are coupled and driven by Mach3. I don't have a Y slide block yet, but Z is traveling nicely!
I'm having some issues with my hobbycnc board; one axis doesn't seem to work at all, and another doesn't give any torque at all. It's a four axis board. Not sure what's going on there
Old 08-21-2009, 12:19 PM
Z car mounted on the Gantry. It's tighter than I'd like... I hope the motor can move it :P
Old 08-21-2009, 03:03 PM
jalessi's Avatar
jalessi is on a distinguished road
Thumbs up
Tmbg,
Awesome work, looks very professional!
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  #11   Ban this user!
Old 08-21-2009, 06:00 PM
FandZ's Avatar
I can see your rails clear enough but what kind of roller assemblies are you useing? Everything looks great btw.
  #12   Ban this user!
Old 08-21-2009, 11:35 PM
they're just oilite bushings.
Newbie - To build or not to build Router/Plasma Table dfranks CNC Plasma and Waterjet Machines 10 04-07-2011 11:16 PM
First machine build, mini mill jbluetooth DIY-CNC Router Table Machines 11 04-04-2009 08:36 PM
Router Using 3/4" MDF (first router build) eguy208 CNC Wood Router Project Log 33 04-11-2008 10:33 AM
Looking 4 someone that would like to build a mini cnc tube/pipe bender for 3/8 dbtoutfit Bending, Forging,Extrusion... 27 10-18-2006 09:45 PM
