Old 06-09-2003, 07:56 PM
Pierre Phe is on a distinguished road
Servos advice
Hello, I am in the process of building a cnc table. I try to keep cost as minimum possible so I decide to reuse a controller that i had wich have 3 servo's ports.
I have no real clue about the software i will use nor the part my controller will handle.
Choice #1: Data (for step motor) will be send across the parallel port of the pc, my actual controller will pick up the data and use it to control servo motor control in close loop, make them acting like stepper.
Choice #2 the one I prefer but...) Gcode files will be transmit across rs-232 to my controller that will have a gcode interpreter build inside and will translate Gcode commands to my servo.
Logically, the choice #1 seems to be the easiest but also the less flexible.
On the other hand, Gcode does not seems to be a big deal to program, but i am not sur if I envision well the task.
Is anyone can tell me if trying to program all the Gcode subroutine in my controller is something that will lock me all the next 5 month in my basement or is it somethings that make sens?
Your advices will be appreciated.
Phee
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!Share on Facebook
Old 06-10-2003, 08:35 AM
ToyMaker's Avatar
ToyMaker is on a distinguished road
It depends
Does your controller have enough memory to hold all the translate routines? Do you know how the G-codes work and how fast can you program?
robotic regards,
Tom
Servos pausing and starting InsaneEPP Servo Drives 9 03-15-2005 09:45 PM
Two servos - one driver WoodSnarfer DIY-CNC Router Table Machines 8 11-13-2004 05:46 AM
software for testing servos? replicapro General CAM Discussion 11 07-21-2004 04:39 PM
Have almost all my parts (pics), need servo advice Darren_T DIY-CNC Router Table Machines 27 01-06-2004 09:20 AM
steppers vs. servos twombo Machine Problems, Solutions , Wireless DNC, serial port 10 06-10-2003 03:43 PM
