Old 08-06-2009, 03:11 PM
wcarrothers1 is on a distinguished road
Servo adapter spacers
Hello...
I know I've seen them but can't find the site now.. In anycase looking to adapt the .5" output shaft of one of my servo motors to a female coupler (that goes into a planetary)..
In anycase I've seen them around, sorta like a collet with a split so it can be compressed and such..
In anycase I'm sure someone can direct.. Basicly want to adapt a .5 shaft to a .75 clamping coupler and clamp them all together.
Perhaps not the best soloution but want to be prepaired to do it this way as I don't think I'm going to be luckey enough to find a planetary gear head with a .5" input this time around. Most seem bigger then that these days.
b.
Old 08-06-2009, 08:37 PM
GaryCorlew's Avatar
GaryCorlew is on a distinguished road
I don't see a size on it but you could check these out
http://www.kelinginc.net/CNCGEARBOX.html
Old 08-07-2009, 07:58 AM
I pretty much have chosen the planetary. since I've had good luck with my thomson I'll be sticking with that brand unit..
In anycase just looing for shaft spacers to adapt the motor shaft to a larger size.
ones I've seen have a split in them to alow for compression and such.
Just another one of those great web site things where I can no longer remember where I saw them.
b.
Old 08-07-2009, 11:38 AM
Here is a pic of what I'm looking for although this isn't the correct dim's..
Anyway still in search of the page/ company.. Had a list of many different combo's of ID and OD's...
b.
Old 08-07-2009, 01:03 PM
Tig Tig is offline
Tig is on a distinguished road
It's been a few years, but last time I checked, You could purchase these
"Input Hub Sleeves" from Danaher Motion for about $25.00 each.
They can be reached at: 1-540-633-3400
Hope this helps.
Old 08-07-2009, 06:26 PM
I sent some mail to my contact there today so perhaps they will get back. I've contacted Thomson (Danaher) a few times in the past to get part number info and they have always been very friendly.
b.
Need A Quote- 6061 SPACERS EDPACECAR Employment Opportunity 3 06-03-2009 10:43 AM
Need A Quote- spacers for project spydermeister Employment Opportunity 7 05-29-2008 07:00 PM
NSK Rails - Replacement balls and spacers? Lionclaw Linear and Rotary Motion 4 02-24-2007 01:36 PM
47mm bearing spacers N4NV Linear and Rotary Motion 5 02-06-2007 07:40 AM
RFQ - Aluminum plate and spacers tjstraz Employment Opportunity 3 01-26-2005 08:25 PM
