Old 08-04-2009, 03:39 PM
phedd is on a distinguished road
Smile My first CNC router, my first post
Hello,
Just getting started routing about a year after I began looking for surplus parts on ebay. X axis is timing belt driven 36" max. running on Hiwin ball bearing slides. Y axis is a thomson unit with 32" of travel. z axis around 2". All were purchased on ebay for less than $300 total. I had steel angle iron frame welded up along with x axis motor mount. The rest is plywood and 2 by 4's. An old desktop serves as the table. Running turbocnc on MSDOS pc driving Gecko controllers. I'm pretty pleased with the performance, but will probably upgrade the y axis motor as it is much slower than the xaxis. Also will be buying a real router to replace the $20 Chinese laminate trimmer.
-Paul in Iowa
ID:	85684   Click image for larger version
ID:	85685   Click image for larger version
Old 08-04-2009, 10:45 PM
FandZ's Avatar
FandZ is on a distinguished road
Hey hey congratulations on your accomplishment! Looks like you are going to have some good fun with your new addiction. Welcome to the zone.
Does anyone have a post proccer for an SCM PRATIX 48 NST 3 axis router that would wor tomvaughan Commercial CNC Wood Routers 1 04-07-2011 06:45 AM
810M MotionMaster Router Post corrigan Post Processor Files 0 03-30-2009 01:23 PM
Post your 3D work done with 3 axis router mrbaseball JGRO Router Table Design 2 11-04-2005 08:22 PM
