Old 08-02-2009, 09:00 PM
Karlf is on a distinguished road
What's your machine size?
I'm curious about the size of machines people are building on here.
What's your X,Y and Z axis.
Do you wish you had a made it bigger or smaller?
What type of work do you do with it?
Old 08-02-2009, 09:11 PM
kolias is on a distinguished road
X=26", Y=48", Z=12" (approx. cutting 24"x38"x9")
I will make another smaller one; we all start with a big one until we realize the mistake.
Hobby router work like picture frames, deco items etc.
Nicolas
Old 08-03-2009, 03:19 AM
*Registered User*
Ultralajt is on a distinguished road
65 x 38 x ~8 cm (X,Y,Z) working area. (~ 25" x 15" x 3")
Link to build: http://www.cnczone.com/forums/showthread.php?t=69838
Mitja
Old 08-03-2009, 06:26 AM
Oaktreeman is on a distinguished road
I can cut 23" by 30". Z is about 3". I recently found ground ball screws on eBay and plan on going larger this winter. Approx 32" by 43" by 4" will be the rebuild. If you have the room, they can't be too big! I mostly make carved signs with it.
Old 08-03-2009, 06:58 AM
johnmac's Avatar
johnmac is on a distinguished road
Mine will cut X: 42", Y: 36", Z: 8". I gave extra room under the Z for bed "inserts", like a vacuum bed, or a big tray to catch splatters if I use coolant.
Mine "will", as soon as I finish the wiring!
John
Old 08-03-2009, 08:04 AM
Yvan256 is on a distinguished road
I'm still just in the planning and learning stage, but if that helps I'm going for a 24x24x2" working area, mostly for wood, MDF, etc.
The 24x24 comes from many reasons:
- 4x8' sheets cut into smaller squares. I can go to the store, buy a 4x8' sheet and have them cut it 4 times.
- The small squares are going to be easier to carry and will fit in the car.
- That size is more than enough for what I'm going to use it for (small bartop arcade cabinets, control panels, etc).
- A 24x24" working area means the unit is not going to be much bigger than a regular tablesaw.
That's the plan anyway, if I'm ever able to build such a machine. I'm still at the motor pinout problem right now.
Roland Modela MDX-3
Old 08-03-2009, 08:37 AM
The J is on a distinguished road
Still a working on the gantry, so I have not updated my own post in a while but my layout is 6' by 8' with a work area of 4' by 6'.
-J
Old 08-03-2009, 10:29 AM
analogman is on a distinguished road
48"X 32"Y 6"Z all aluminum machine based on the data cut plans. With Chinese water cooled spindle.
Use it about 6-8 hrs per week for small production building of parts for electronic equipment - cutting aluminum chassis, circuit boards, engraving faceplates, cutting cases.
Old 08-03-2009, 10:34 AM
GeeksGoneBad is on a distinguished road
Mine get's about 47" X 32" X 6" as well and it's just about the perfect size for me - so far I'm making signs, and I plan on making some guitars
Check out my projects at www.backyard-workshop.com
Old 08-03-2009, 11:47 AM
m-rage is on a distinguished road
Hello together!
My (just finished) CNC has a working area from about 730x350x140mm.
I started with cutting Logos but soon I am trying to do 3-D-work.
  #11   Ban this user!
Old 08-03-2009, 07:42 PM
Broken Balsa is on a distinguished road
My machine is a JGRO. While not as cool looking as some I have seen it gets the job done. I can cut 14" Y by 32" X by 8.5" Z. It operates between 6 and 16 hours a week. I build camera mounts for radio controlled aircraft. Also make after market parts for small electric planes. It has been at work now for almost a year with no problems. I do my design work on Turbo CAD in conjucntion with Cut2D and Mach3. I find that a very good combination for what I do. I mostly cut G 10 but once in a while I do cut a sign for someone. I may build a larger machine down the road that is all metal so I can use coolant and do alumium. We have a K-2 which is smaller and it can make small alumium parts when needed. For now we have things pretty well covered.
ID:	85620   Click image for larger version
ID:	85621   Click image for larger version
ID:	85622   Click image for larger version
  #12   Ban this user!
Old 08-03-2009, 08:35 PM
pedipinha is on a distinguished road
I am form Brazil, and my machine have 3000mm x 2400mm y 200mm z, and I will work with MDF for mobile.
MACHINE SIZE LYN BYRD Mach Software (ArtSoft software) 6 04-17-2008 12:42 PM
Servo size for this machine XLR84x4 DIY-CNC Router Table Machines 2 06-08-2007 01:11 AM
Need help choosing a mid-size benchtop CNC machine sp1nm0nkey General Metal Working Machines 1 07-03-2006 08:44 PM
Servo size for this machine? DennisCNC Mechanical Calculations/Engineering Design 9 04-19-2006 08:24 AM
What size machine to build? CNCMP DIY-CNC Router Table Machines 6 01-04-2005 01:36 PM
