Ok guys, been surfing and searching the forum for the past 2 days now and I am still not exactly clear on what to do. So far i have the table of my machine built, its 3'x5' and i have my x-axis rails welded together i went with some mild steel tubing and angle iron, and i am making the skate bearing rails. The gantry will be made out of MDF and a piece of steel or two and the router i plan on running for now is a small trim router, but eventually would like to run a high hp router or a 1.5 or 2kw spindle. After reading through many posts and seeing many different ways of making the gantry move there are several options. Such as the following: Belt Drive, Chain Drive, ACME Screw, Ball Screw, ect. My first question is this: Can i get away with a single screw in the center of my gantry underneath or is it better to try and put a screw on each side of the gantry? Secondly: I am really leaning towards the ACME screws since they are wallet friendly for my recently graduated engineering unemployed self. They are under $7 per foot at Rotron, and i am looking at say a 1:1 speed ratio, but what about starts and TPI? Any recommendations? Also i have been reading about the "backlash" i plan on getting Anti Backlash nuts from dumpsterCNC.com. Third: After looking at speed ratio's if i go with a 1:1, mcmaster says it would move approximately 1/10th of an inch per revolution, would i gain more precision and accuracy out of the table if i did a gear reduction from a stepper motor to the screw? or would direct drive provide me with more than enough? I plan to cut mostly wood, do some carving, and cut aluminum. I appreciate any help i can get, I am new to the construction aspect of a CNC, but i have used many including some large HAAS mills in an internship and at college during an automation course. I will be using MACH 3 for my controlling software and purchasing steppers from wherever, looking in the 300 oz/inch + range when i get that far. Thanks, Andy |
| If you go with acme from Roton, these will give you much more speed, with the correct motors and drives. http://www.roton.com/Mating_Componen...family=7060986 With direct drive, 1 revolution will move 1/2". Keep in mind that the motors, drives and screws need to work together as a complete system. So you'll need to choose motors and drives that will work with those screws, and your machine.
| Thanks Gerry, After looking around the forums all day, i see what you are saying about using a "slow" or low travel per revolution on a screw, the machine would be sooo slow. I think i am going to go with what you have posted above, and along with their anti-backlash flange nut as well. Question is will that rod come with machined ends for bearings? or will i have to outsource that? Thanks for the help. Its greatly appreciated! Last edited by Trucks; 07-30-2009 at 11:42 PM. |
| Another silly question. Does anyone else sell anti-backlash nuts for that type of rod? I was looking at the one for that rod that rotron sells, and it says its good for 25lbs?? I think my gantry is going to be more than that. Should i upgrade to a larger diameter rod? Thanks. |
| Here are the ones i run http://www.finelineautomation.com/st...g?tag=LeadNuts And here are another type http://www.dumpstercnc.com/ Not sure about the 25lbs rating. I havnt broke one yet and im pulling a 100lbs gantry.
__________________ Nick I Know I Cant Spell..Don't Remind Me Last edited by finishlinewrx; 07-31-2009 at 12:24 AM. |
| I do have two drives on X. And remember that it is a rolling load. My gantry weighs close to 100lbs but might only take a few pound to move it.
__________________ Nick I Know I Cant Spell..Don't Remind Me Last edited by finishlinewrx; 07-31-2009 at 12:36 AM. |
| Simple, 3 Axes with Dual Drive/Motor (per axis), hardware splitter drive Interface. | kreutz | Stepper Motors and Drives | 3 | 07-03-2008 06:57 PM |
| mach3 and ormec ac servo/drive help for a newbie | bseibenick | Servo Motors and Drives | 0 | 02-19-2008 08:11 PM |
| Newbie questions gecko drive limit ? | Calico | Gecko Drives | 0 | 04-03-2005 05:15 AM |
| Newbie Servo Drive Question? | chas | Gecko Drives | 0 | 03-31-2005 12:02 AM |
