Our Mistergram Engraver at work just stopped working and they need 2 signs made ASAP. Just some lettering on lamicoid sp? All I have is my newly build router and Mach3. Is there some way to quickly do this? I have AutoCAD and can probably get any software I need… Thanks |
| Is it software that your looking for ? you can create some neat stuff with inkscape and save it as dxf http://www.inkscape.org/
__________________ A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org |
| Here is a link to a demo version of SuperCamXp. http://www.super-tech.com/root/grp.a...uperCamXp-Demo You can import the DXF file and then export the G & M code files. The EXPRTCNC on right sidebar menu will create the G & M code file. There are surface, altitude and cut depth parameters that set where the code will occur in the Z coordianate. Course if you had a USB CamPod you would not even need Mach3 and you could work directly with the DXF files and the machine. SuperCamXp normally comes with the USB CamPod which is a USB to Parallel Port adapter for machine motion control. Hope that helps. Dennis www.super-tech.com |
| http://shopcam.com/ try the demo , its fully functional for 30 days and will produce code , its a product that Ive taken onto my site and I absolutely love it , if you try it then import a 2000dxf . here's an aluminum example of something that i was playing with using shopcam today on my day off
| I will give them a try tomorrow after work. Before baseball this evening I downloaded "Font 2 DXF and G-Code 3.0" I got home and exported the DEMOVER test that is all the demo version will allow and it worked flawlessly. I had to tweak the Z depth but it cut the lamicoid perfectly. I might like using this CNC router |
I'm sure you will , its a great pass time
| It turns out that the software at work (SignLab) will export to G-code. It has 3 different g-code options gc1, gc2 and gc3 I have no idea what the difference or if the files will load into Mach3 and run. I may have to tinker with the code, but it is a start. If I were to post parts of the three export files would someone let me know which one would be better suited to Mach3? Thanks Last edited by Drools; 07-28-2009 at 10:01 AM. Reason: added comments |
Sure.
| SIGN Making methods? | esmiller | General CNC (Mill and Lathe) Control Software (NC) | 8 | 05-23-2008 10:49 AM |
| Need Help!- Sign making software? | jeffmorris | General CAM Discussion | 16 | 04-02-2008 10:33 AM |
| Newbie- simple sign making | mc-motorsports | Vectric | 2 | 03-23-2008 01:17 AM |
| BobArt for Sign making? | pecosjoe@yahoo. | BobCad-Cam | 24 | 10-05-2007 11:52 AM |
| Plasma CNC for Sign Making | Robin3295 | CNC Plasma and Waterjet Machines | 7 | 04-27-2007 06:17 AM |
