Old 07-25-2009, 04:07 PM
eloid is on a distinguished road
cycle routor on/off via mach
I want to now add the feature to power on and off my router
via mach for bit change out and power off during e-stop etc,
I know you need a relay etc a signal =+5-15v for the control
for the bob to the relay
The question is, what code do I need to have etc or is there a canned
script I can use? Im Using cnc4pc c23 bob with smooth stepper.
Old 07-25-2009, 04:34 PM
GaryCorlew's Avatar
GaryCorlew is on a distinguished road
Set up one of your output pins for the relay, then go to spindle setup and make sure disable spindle relays is not checked and select the output for the pin you setup
Old 07-27-2009, 11:22 AM
jsheerin's Avatar
jsheerin is on a distinguished road
Also, the basic gcode commands are M3 and M5 to turn your spindle on and off once you've setup the relay for it. You can pop up a screen in mach that shows you all the m codes.
G76 CYCLE BAD DOG General Metal Working Machines 2 09-20-2008 04:33 PM
How do I convert a cnc routor to a water jet? ariel 1 CNC Plasma and Waterjet Machines 5 02-19-2007 05:43 PM
Confused: Mach Turn, Mach Mill, Mach 2/3 ? CanSir Mach Software (ArtSoft software) 5 02-16-2007 04:41 AM
Moving to mach 3 need exact mach 2 screen carlnpa Mach Software (ArtSoft software) 2 12-11-2005 03:00 PM
will mach 2 or mach 3 work for 4 axis cnc? Runner4404spd Mach Mill 3 10-05-2005 11:44 AM
