Old 07-25-2009, 11:59 AM
ballbearing is on a distinguished road
Gecko Servo Drive Current Issue ??
I have Brushed DC Servo Motors that draw a peak current of 40 Amps And
I want to use Gecko 340 Drives. My Power Supply also puts out 75 Volts and
40 Amps. After reading the Gecko specs. I see that they can only handle 20 Amps.
Is there a way that I can get all this to work for me ?
Any Help would be greatly appreciated
Cheers
John
Old 07-25-2009, 12:09 PM
ger21's Avatar
You can use everything you have. However, the Geckos will only supply 20 amps max, so you'll be limiting your peak torque to half of what it's rated at at 40 amps.
Old 07-25-2009, 03:03 PM
Bubba's Avatar
Bubba is on a distinguished road
You really don't want to operate at the peak current anyhow (if I read your spec's correctly) as this is were you can get into de-mag problems. Your power supply is rated to 40 amps, but it will only put out what is needed (in this case max of 20 amps per axis) so if you have three axis you will probably be ok anyhow.
Art
Old 07-25-2009, 05:51 PM
Thanks Folks !
I think the world is somewhat safer again. I won't cook my drives and given the physical attributes of my Machine I can't see me exceeding 20 Amps @ 75VDC... so I am back on track !
Cheers
John
Need Help!- The Gecko 320 servo drive Trump Bridgeport and Hardinge Mills 2 07-16-2009 06:32 PM
Driving 160v servo from gecko drive ahmedrehan Gecko Drives 1 10-06-2007 09:05 PM
How to measure the current on Gecko drive. cnc2k Gecko Drives 12 11-16-2005 12:16 AM
gecko 210: low current draw? anthony Gecko Drives 2 05-28-2005 02:19 AM
