Old 02-22-2005, 12:35 PM
JavaDog's Avatar
JavaDog is on a distinguished road
Z-Axis Quandry
I was curious, most people have dual linear slides on their Z-Axis...
But would a single slide like this:
work?? I would be using a Porter Cable 1 1/2 hp router, if that makes a difference.
Old 02-22-2005, 12:55 PM
BigDaddyG is on a distinguished road
JavaDog,
Yes, that will work just fine. That wide type of track is (somewhat) equal to using dual tracks. The ratings on that rail / track are going to be far and above what you need, and you save space and time. In my never to be humble opinion, go for it...It will work fine.
Regards,
Glen
Old 02-22-2005, 01:07 PM
JavaDog's Avatar
Cool, that's what I was hoping for. It'll make the placement for the ballscrew a bit more tricky...but no big deal.
Any idea on what a fair (used) price for these is?
Old 02-22-2005, 03:19 PM
pen25 is on a distinguished road
i have seen these going on ebay pretty cheap... like buy it nows for something like 20 bucks. i have to go back and check though
Old 02-22-2005, 03:25 PM
sorry they are 50 "This is a Brand New Precision Crossed Roller Slide Assembly manufactured by Del-Tron, No. RS2-3." not the same thing but looks to be much more stout
Old 02-22-2005, 03:58 PM
JavaDog's Avatar
Yeah, I've seen those. Some of them have great load-ratings (75lbs or better on some) but the travel is usually on 1" or 1.5". A wee bit smaller than the travel I was looking for.
I would imagine they would be great if you were doing a lot of 1/4" and 1/8" etching, sign-making, etc...
Last edited by JavaDog; 02-22-2005 at 04:00 PM. Reason: Because I can't seem to type today...
Old 02-22-2005, 04:08 PM
think the one i posted was 3" travel. I didnt see any as wide as you posted but did see a couple 1.5" wide i think for 14 bucks
Old 02-22-2005, 04:46 PM
JavaDog's Avatar
How are you searching for them on ebay...I must not be finding all of them.
Old 02-22-2005, 05:25 PM
i just searched cnc also try linear slide
Old 02-22-2005, 11:33 PM
Evodyne's Avatar
Evodyne is on a distinguished road
Smile Other search options
I usually search using linear rail AND linear slide (2 searches). Use wildcards: linear rail* will return linear rail and also linear rails (plural-most people sell them in pairs). Ditto linear slide: search for linear slide*. Also, just use the vendor names: THK, Thompson, and NSK.
The wildcard thing works well for motors too: step* motor* will return results for step motor(s), stepper motor(s), stepping motor(s), etc.
You might consider the ground round shafts with roller bearings for you axis.
Also, consider complete slides with motor mounts, rails, screws, limits, and so on. More money up front, but they are a "canned", pre-built solution and you can save in the long run.
4020 4th axis problems little bubba Fadal 3 06-13-2005 10:08 PM
No Encoder Counts On X Axis. Y=OK murphy625 CamSoft Products 5 03-08-2005 09:20 PM
2 axis to 3 axis conversion drembedded Bridgeport and Hardinge Mills 10 10-27-2004 12:32 PM
fourth axis indexer senor J. DIY-CNC Router Table Machines 1 08-04-2004 04:34 PM
My Lathe project; might CNC it one day Stevie General Metal Working Machines 86 06-21-2004 09:27 PM
