Old 07-22-2009, 11:38 AM
Trucks is on a distinguished road
Newbie Help on Stepper Motors
Hey guys, i posted on the controller cards portion of the forum, but no one seems to be able to help me.
Here is the stepper i have:
It has 5 wires that come out the back, and on the back of it there is an encoder mounted, which has no wires coming off of it at all.
I am wondering if anyone has suggestions on how to wire this up, since i see most controllers are for 4, 6, or 8 wires. I have not found a single one that is 5 wires.
Any one with help is appreciated, i want to get my machine moving this week, but without a controller its a little hard to do.
Thanks, Andy
Old 07-22-2009, 12:02 PM
15mgtar is on a distinguished road
Hi, I think you have an unipolar motor and can not be wired as bipolar because you have 5 wires. About the encoder I don't know anything about stepping motor using encoder.
Old 07-22-2009, 12:08 PM
thanks, im thinking that this motor is a total bust.
Anyone? I am thinking now it would be easier to return them and just get several Nema 23's and a controller card....
Old 07-22-2009, 12:36 PM
ger21's Avatar
It's very weak at 66oz-in, and it's only 24 steps/revolution. Virtually all steppers used on CNC machines are 200 steps/rev.
Old 07-22-2009, 01:41 PM
Ok, thanks that's a big help. So i went and returned the 1 of 2 because i clipped the cable off the other one, i will find a use for it some other place. I guess i am going to shoot at building a larger table now, since i will be getting larger motors.
i guess maybe looking towards like a 160 oz -in motor or some where in there
My original table was only 24" x 18" wide, i think i will step up the size to something maybe 24" wide x 36" long? I was going to build a small one first to work out the bugs, but after several hours looking at others larger machines, i should build one that will suit many future projects to come.
Thanks guys
Old 07-22-2009, 04:14 PM
ger21's Avatar
There's a good chance you'll end up heavily modifying or even building a second machine.
Depending on what drives you'll be using, you can get ~300oz motor from Keling for $40.
Old 07-22-2009, 04:18 PM
Ok, well the more i think about it, the more i am leaning on making a larger machine for my first one. I will look into the motors at kelling.
Thanks for the input! its greatly appreciated.
Old 07-23-2009, 12:48 PM
get the largest motor you can afford so if you decide to step up to even more bigger table you won't have to buy bigger ones.
I'm not really sure about this but I think Keling gets their motor from www.ms-motor.com which is from China you will see a BIG price different there. I bought my 1,699 oz and drivers from ms-motor and they run beautifully.
Old 07-23-2009, 04:56 PM
analogman is on a distinguished road
Thanks guys
FWIW I skipped the "build a small machine first" and went right to building a machine that suited all my needs. I am very skilled at CAD, computers, machining, mechanics and electronics so all that helped. I built an all aluminum Data Cut machine 32x48.
Old 07-23-2009, 08:00 PM
Ya that is exactly what i am doing now. Headed to the Home Depot to get some supplies, hope to have the frame built by tomorrow night, ordered a ton of skate bearings from VXB for practically nothing, going to try the angle aluminum slides, if anyone has a suggestion as to what size aluminum it would be greatly appreciated!
  #11   Ban this user!
Old 07-23-2009, 09:19 PM
MadeInTheShed's Avatar
MadeInTheShed is on a distinguished road
I used 20x20x3 aluminium for the rails and 25x25x3 for the bearing carriers. These fit nicely with 22x8x7 skate bearings. If I do mine again, I will use a different setup for the bearing carriers so that the bearings are in line with each other and not staggered.
jon
  #12   Ban this user!
Old 07-23-2009, 09:50 PM
Ok, thanks for the tip. Ya i scored the same bearings, i got 32 of them for 20 bucks, with free shipping on ebay, i couldn't pass that up.
Thanks for the help guys, i love this place.
Just IN- Provide controllers,drives,servo motors,stepper motors,electronic parts from China Ling Product Announcements & Manufacturer News 2 07-12-2009 04:10 AM
Newbie Question re motors coldspot General Metal Working Machines 0 12-29-2008 02:22 PM
Need a little help? with 8 wire stepper motors total newbie stevef12005 Stepper Motors and Drives 1 12-18-2008 06:08 AM
Wanted DIY stepper driver circuit for 6 wire stepper motors Colin300 Australia, New Zealand Club house 5 09-20-2007 09:20 PM
stepper motors or servo motors? jprobst Torchmate 3 07-13-2007 05:37 PM
