I know this might wrong place for this, but. I have in my possession, two pair, of some very hardly used roller blades. I want to remove the bearings from the rubber wheels and I don't have an arbor press. Can anyone suggest a way to remove them?. There are two on each axle, so I can get up to 32 of these little beauties! |
I've taken bearings out using the largest punch I can fit through the center- gently tap your way around till they come out. They shouldn't be in there horribly tight anyway. Once you get one out, find a socket with a nearly the same outer diamter as the bearing in tap it out gently. Rollerblades and skateboard bearings are usually the same size- you could check with a neighborhood kid and see if he has a bearing tool. It's just a stepped cylinder that fits in the middle. Sometimes you can just stick it in and wiggle it sideways a bit. Hope that helps- don't go too ape on them with anything metal or you can foul up your treasures! ktow |
| skate bearings versus linear bearings | paul langwade | Linear and Rotary Motion | 7 | 05-29-2006 10:06 AM |
| Skate bearings on CRS rod | bobh | Linear and Rotary Motion | 9 | 05-24-2006 05:40 PM |
| Skate Bearings | aggie_67 | DIY-CNC Router Table Machines | 1 | 03-03-2006 06:38 AM |
| RFQ: Skate Bearings | coolman | Employment Opportunity | 3 | 05-17-2005 07:20 PM |
| A question on bearings......to skate or not to skate | HiString | DIY-CNC Router Table Machines | 1 | 11-12-2003 01:46 AM |
