Old 07-20-2009, 11:18 PM
FandZ's Avatar
FandZ is on a distinguished road
All metal Z-axis design useing skate bearings and cold rolled steel
Hi all, I'm getting closer to starting a build for my next machine. On my last build, my Z axis really caught me by surprise so this time I'm starting with my Z axis.
If you look at the pictures below, All the dark metal is cold rolled steel. The roller assemblies would be 1/2 in. x 1/2 in. and the rail would be 1.5x1.5 cold rolled steel. The aluminum would be .5 inches thick except for the anti backlash nut plate and the stepper mounts. Total Z travel would be between 5 and 6 inches.
Besides the width of the bolts shaft, none of the bolts are to any exact specs but they are close. I may go with allen bolts but I haven't decided. As you can tell there will be a lot of drilling and tapping at hand. Oh and I also left out the spacers for the bearings and lock washers. They will not be rolling on the very edge.
As far building it, my local metal supply shop will be cutting the metal to length and my current cnc would be used to mark the metal for drilling on my drill press to get the tight tolerances I'm looking for.
I'm still working on it but if anyone has any concerns or suggestions on this design I'd be glad to hear them. The only concern I really have is how the .5x.5 roller assembles extend 3 inches after the bearings for the spindle mount. My goal is to comfortably work in aluminum.
ID:	84746   Click image for larger version
ID:	84747   Click image for larger version
ID:	84748   Click image for larger version
Old 07-21-2009, 05:42 AM
CarveOne is on a distinguished road
I suppose that 1.5" x 1.5" steel rail won't be bending anytime soon.
It's an interesting design concept. I would recommend changing the steel spacer block behind the router mounts to aluminum to lighten the moving load on the stepper by that much. I think there would be no strength advantage in it being steel for that application.
The four steel bearing bars may be strong enough if made of aluminum, but it's probably better to overbuild those than to underbuild them. .5" x .5" aluminum might be a little marginal here.
Do you plan to place the Y axis lead nut behind the vertical aluminum plate?
CarveOne
CarveOne
Resistance is not futile. It is voltage divided by current (R=V/I).
Old 07-21-2009, 05:47 AM
Regnar's Avatar
Regnar is on a distinguished road
The design looks good and simple to construct. What could make it easier is if you shortend the 1.5 square cold rolled steel and extended the 2 aluminum pieces that have the bearing attached to them to go over the steel stock. I think you will find that it might be hard to drill 2 holes straight through 1.5 inches of steel to meet up with 2 threaded holes in aluminum. Drill and thread the steel on the ends and drill the holes through the aluminum. This should also help in keeping everything square if the steel is cut square.
I hope you plan the rest of the machine to be beefy. This Z axis is going to weigh a pretty considerable amount.
Also for the stepper mount you might find it easier to make these out of square or rectangular aluminum tubing. This way you can bolt down rather than up. If you make the mounting holes a little larger you can move the stepper motor around if everything doesnt line up as nice. Right now you have to be dead on.
Old 07-21-2009, 06:07 AM
The solid steel bar will be very heavy, but it is at least not a part that the stepper has to lift. I was going to suggest making that rail out of 1.5" x 1.5" x .120" steel box tube to save on weight, but I went out to the work shop and looked at the 1x2 and 2x2 box tubes I have and though 5/16" wide bearings would roll at the radiused corners ok, there are little ridges that make it dimensionally problematic. The ridges could be lightly oil-stoned off but I doubt that anyone would be happy with the results. The ridges are left during manufacturing by swaging the tubing to size.
CarveOne
CarveOne
Old 07-21-2009, 09:12 AM
Regnar's Avatar
Just another thought, if you were to mount the leadscrew off to the left or right of your 1.5 square bar you should be able to bring every thing in closer to the y axis so that the weight doesnt stick out as much. Again just suggestions dont know what the rest of the system looks like or what else you have in mind.
CarveOne, I was also thinking he could do some lighting holes down the center of each side. Make half inch hole skip and inch and do another. I dont know how much it would help but I dont think it would hurt in anyway either.
Picture of all the ideals into one.
Name:	Untitled (Medium).jpg‎
Old 07-21-2009, 05:19 PM
-Snip-
That will be one way to do it. Another is to drill a 1/2" hole (or 3/4" ?) into the top and bottom hole as far as a drill will go, centered in the ends of the bar.
If overall gantry weight is not an issue I would just leave it solid. On my 2nd build I avoided steel as much as I could in the sliding part of the Z assembly.
OOPS!! Forget the hole in the ends idea, I see bolts there.
CarveOne
CarveOne
Old 07-21-2009, 08:58 PM
FandZ's Avatar
Hey guys, thanks so much for your suggestions. Just the kind of feedback I知 looking for.
I知 not too worried about weight so much, In fact, I知 aiming to have a heavier machine over all to reduce vibrations in the hopes of a better finish. I say heavy but I知 thinking it値l end up weighing around 200 to 250. Most of that weight will be over the cutting table as I知 designing with the X axis suspended above the cutting table. Sort of parallel with the Z axis. I guess that is not so heavy really. Should be interesting. I would post the design but I壇 hate for someone else to build something close to it before I have had the chance lol..
What could make it easier is if you shortened the 1.5 square cold rolled steel and extended the 2 aluminum pieces that have the bearing attached to them to go over the steel stock.
I see what you are saying. I originally designed it that way but the place doing the cutting gives a 1/16th of an inch plus or minus on cuts. The way I have it I知 using 3 inch wide bars of aluminum cut to length so I won稚 have to worry if my steel bar is 1/16 too short or long. Hrmm but it would be easier to mount it with your way. I値l post a picture of an idea.
I may just have to go with your idea on the stepper motor. I was planning on making the holes for the bearings that hold the acme rod bigger but it may be better to just have to adjust the motor than both of those.
CarveOne
On my last machine I used 1x1 steel tubes for rails. It worked fine but the finish isn稚 that great as you suggest and there are low spots where one bearing can be turned in place. Not good, I知 sure.
Just another thought, if you were to mount the leads crew off to the left or right of your 1.5 square bar you should be able to bring everything in closer to the y axis so that the weight doesn稚 stick out as much.
Hrmm.. I originally started with two 1.5 inch steel bars and an acme screw near the center. It saved a little over an inch but I decided it was a little too much..lol I値l post a picture.
The suggestions to drill holes to reduce weight are great. I never thought of that. If my Y axis struggles I will do it for sure. For now I plan on leaving it solid. I知 wanting the weight.
Someone mentioned it may be hard to drill straight through the steel bar with accuracy. I was wondering about this. What do you think if I try it first and if the ends are off I drill a bigger hole through half of it on the side that mates with the aluminum shelf? Or maybe drill the bigger holes first and then only have to drill シ an inch precisely with a smaller drill bit on the other side?
Again. Thanks for the suggestions
Old 07-21-2009, 09:12 PM
FandZ's Avatar
Idea and first design.
Now that I look at the big I dea it would further the distance of the rail. I think I'm just going to have to man up to save that half inch.
ID:	84841   Click image for larger version
Name:	Double rail.jpg‎
Old 07-21-2009, 09:24 PM
Originally Posted by FandZ View Post
- snip-
If you are talking about an end to end hole, the bar is probably too long for most 1/2" drills to reach deep enough to meet at the middle, and they are very likely to not be aligned. In this case it will not matter much, as it can't be seen anyway. Not meeting in the middle is no problem either. It could be finished with a boring bar in a lathe. Boring bars that fit a 1/2" hole are usually very limber.
Drilling crosswise holes should not be a problem if a sharp bit is used. A split point drill will stay on course better than a regular drill.
CarveOne
CarveOne
Old 07-21-2009, 09:34 PM
FandZ's Avatar
CarveOne
It was the cross wise I was worried about. thanks for tip on the drill bit tip.That's what I'll get and do.
  #11   Ban this user!
Old 07-21-2009, 09:57 PM
Jason Marsha is on a distinguished road
FandZ,
Not sure if my assemblies are from hot or cold rolled but I used 16mm (5/8") solid square bar and the holes for the bearing bolts had to be drilled halfway through from each side because the bar was not square. I also had to use a center punch to stop the wandering bit whether split point or regular.
Jason
  #12   Ban this user!
Old 07-21-2009, 10:16 PM
FandZ's Avatar
Originally Posted by Jason Marsha View Post
FandZ,
Jason
Cold rolled is known for it close tolerances so it better be square or me and the shop will be having a talk lol... I was going to use my existing cnc machine as a high tech punch to mark my drill points. I may make some sort of tool to hold my punch and align it from the edges. On my last build I wish I would have made a punch holder because scribing lines and then punching didn't work out too great for me. I did a lot of redo's.
cutting oil for 1/4" cold rolled steel? groomden DIY-CNC Router Table Machines 13 03-18-2009 11:50 PM
Cold Rolled Steel Accuracy Zach_G Mechanical Calculations/Engineering Design 13 11-25-2008 08:59 PM
Cold rolled steel, flats or square for use as rails. Apples Linear and Rotary Motion 10 08-09-2008 12:22 AM
New Truck Design - Angle Iron & Skate Bearings datacop Open Source CNC Machine Designs 0 07-12-2006 10:24 AM
Need to cut 1 x 4 cold rolled steel - Product Review jderou General Metal Working Machines 17 07-06-2005 11:24 AM
