Old 07-15-2009, 06:01 AM
Donny Strange is on a distinguished road
Lack of Vacuum
I use 8x4 10x5 feet sheet material, the 8x4 vacuums beautifully but i have trouble getting the 10x5 to stay down and the machine is constanty stopping halfway through programs. Im using interior grade mdf as a slave bed, ranging from 12mm to 8mm thick.
Is there any hints or tips that anyone could give to get the vacuum numbers up?
Old 07-15-2009, 10:00 AM
Dropout is on a distinguished road
What is the thickness of the material that you are machining? I have no problem with 3/4 (19mm) but 3/8 (~10mm) keeps lifting off the table. A downcut or compression bit shoudl solve my problem.
Old 07-15-2009, 11:05 AM
im packing both the compression and the down's, on the 10x5 im using 4 and 6mm ply which understandably im going to have problems vacuuming purely because of the "waveyness" of it. However i also use 15mm high grade 11 layerd ply, so its big and heavy so cant understand why im losing vacuum on it. Im convinced theres a leak somewhere
The Lack Of The One Program To Do It All And Do It Right berin OpenSource Software 7 01-15-2007 12:15 AM
Spindle speed range or lack of it! creep_pea Bridgeport and Hardinge Mills 7 10-04-2006 04:42 PM
Major lack of torque with steppers curtisturner Stepper Motors and Drives 16 07-05-2006 09:26 AM
Complete Lack of Experience rcazwillis General Metalwork Discussion 6 12-04-2005 08:48 PM
PICStep and the lack of updates! Garfield2 PicStep Controllers 2 05-21-2005 05:00 AM
