More Problems?? I think im losing steps? its the only thing i can think of its doing. I ran through the step calcultor for motor tunning and it will be right on durring the calculator. But running a program it seems to lose where it's at. Only seems to do it when i try running something that is moving my X (dual drive axis) back and forth in small increments or something that is moving Z up and down profiling. then Z keeps getting lower and lower the longer it runs? Could this be a backlash problem? or a drive problem. G540 4 axis package (One G540 + Four KL23H284-35-4B (1/4” Dual shaft with a flat) 387 oz-in + one KL-350- 48 48V/7.3A 115V /230V power supply: $544.95 here is what im running ^^. i have been reading that the psu is not big enough for 4 motors. Will that lose steps?
__________________ Nick I Know I Cant Spell..Don't Remind Me |
| It could but the likelyhood would be that you would see the effect in all axis, not just one. Check you coupler for slipping.
__________________ Phil, Still too many interests, too many projects, and not enough time!!!!!!!! Vist my websites - http://pminmo.com & http://millpcbs.com |
| why not try low cost closed loop AC servo with high resolution absolute encoder, from www.dmm-tech.com HL |
| I'm with pminmo on this one. It sounds like you need to cinch down the coupler screws really tight, especially if they are Delrin or other type of plastic. Plastic will cold flow under a lot of pressure from the screws. It may take a while, but it will eventually happen. CarveOne
__________________ CarveOne Resistance is not futile. It is voltage divided by current (R=V/I). |
| Problem- Losing steps?? How do I know?? | JeLC | DIY-CNC Router Table Machines | 28 | 09-09-2009 06:26 AM |
| Im LOSING steps?! | Starleper1 | Benchtop Machines | 4 | 07-02-2009 08:59 PM |
| Help with CNC losing steps | Scramjet | DIY-CNC Router Table Machines | 6 | 01-29-2008 06:24 PM |
| Losing steps - WHAT IS UP?!? | Sporqster | DIY-CNC Router Table Machines | 10 | 04-27-2006 09:50 AM |
| Cause For Losing Steps? | FLUTE HEAD | TurboCNC | 7 | 06-14-2005 07:54 AM |
