Old 07-14-2009, 11:01 AM
Herbertkabi is on a distinguished road
5-axis Gantry Mill progress
hi everybody,
Despite of world wide crisis I started with my new mill I have planned and drawed during past 8 months.
5-axis.
Added sketsh (not all components are drawn).
This is composite mill - used massive Aluminium up to 80mm thick, machined artifact commercial granite panels. All gaps and emty places filled with composite-granite between thoses.
X-"walls" are 75mm thick (hight > 500mm), Y-bridge is machined from 650x210x78mm solid Aluminium, Z-axis made from 600x170x78mm solid Alu. There are no main parts thinner than 15mm Aluminium. Face U pate is 15mm thick aircraft aluminium ...
Stationar table surface is 650x630x30 pressed granite, total thickness of table 78mm. There are diamont cut holes though, there will be M8 hollow bronze plugs 80mm long ... 4/5 axles will come bit later, when main machine is ready. 4-th axis is 250mm wide, 80mm thick, 5-th axis table has 180mm diameter. For driving 5-th axis I use FA15/49 Cyclo drive (integrated in to ...), for 4-th axis I have FA35/109 - I hope to change this for smaller one ...
X,Y,Z axis uses ISEL 16/5 ballscrews with TWO zero backlash nuts for each.
X axis gas two sets of screws/touble nuts.
Z -> 2 rails 4 cars SHS20LV, Y -> 2 rails 4 cars HGW25CC, X -> 2 rails 4 cars HGH25HA. My first ATC spindle is also ready.
I already bought 5 x VCD-E (+5 servo motors) from www.granitedevices.fi .
Mach3 (15-350 Model) also ordered - hopefully next week I can touch it with my own hands.
http://www.machmotion.com/CNC-Contro...duct_info.html
http://www.machmotion.com//c30/p60/X...duct_info.html
Several parts are ready and I started with frame up. It will be very hard, but I hope ...
Im sure you wonder - why such kind of strange design ...
Yeah, but why to build separate screens and cabinets?
Regards,
Herbert
Old 07-14-2009, 11:12 AM
Gap between pressed granite and aluminium sides will be filled with composites when all parts mounted, leveled, measured, checked over and one time more leveled ...
Why I choiced this commercial pressed granite? Because Im not sure able Im to get so perfect surface.
Herbert
ID:	84391   Click image for larger version
Old 07-14-2009, 11:23 AM
Y-beam. L-650mm, 210mm wide and 78mm thick - hopefully rigid enough.
Sketch shows how mounted with end blocks.
Special Thanks to Dan Falck - converted my DWGs to STP,
Regards,
Herbert
ID:	84395   Click image for larger version
ID:	84396   Click image for larger version
Old 07-14-2009, 11:36 AM
Z-pillar (beam?) is also machined but lot of things need to be done before its ready ...
As you can see - also very massive
You can see all rails, ballscrews, cyclo drives, 5 x VCD-E (+5 servo motors) from www.granitedevices.fi ...
No more photos yet.
Cheers,
Herbert,
goes back to workshop
ID:	84399   Click image for larger version
ID:	84400   Click image for larger version
ID:	84401   Click image for larger version
Old 07-14-2009, 11:49 AM
idtkid's Avatar
idtkid is on a distinguished road
awesome build so far, I will be looking for more updates and pics!
Rockcliff PE/Aluminum Router > 4'x8' CNC Router/Plasma > Manual DRO/CNC X2 > 4 Axis Syil SX3 and an Emco PC Mill 125
Old 07-15-2009, 07:34 AM
Seems impossible without problems.
Today morning I bring back to factory these pressed-granite panels. The hight of sides was near 1mm over and thickness was not exact what ordered - they forgot to over-grind the back side.
Tomorrow afternoon hopefully will be done.
Such kind stories are very tiring
cheers,
herbert
Old 07-16-2009, 10:33 AM
Problems solved, now composite panels fits correctly
When all parts ready then will go on with frame up.
Lot of threadings ... dog-tired
Regards,
Herbert
ID:	84492   Click image for larger version
ID:	84493   Click image for larger version
Old 07-16-2009, 12:25 PM
sonicwonder2000 is on a distinguished road
Beautiful build! It looks VERY sturdy, are you planning on machining metal with it?
Old 07-16-2009, 12:33 PM
jalessi's Avatar
jalessi is on a distinguished road
Post
WOW
AWESOME WORK
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 07-16-2009, 04:14 PM
Idea was to get it sturdy, rigid, no resonances ... not like our older diy does.
and to get away from building separate cabinet/ enclosures,
Yes - sliding front door will come, not drawn on the sketch.
Whereby rorary stages of 4(5) axis mounted into side walls,
It is semi-composite-granite-aluminium built
Automatic tool change, self-washing, central lubrication ...
We milling most of all aluminium,
But will see - perhaps even some steel.
Regards,
Herbert
  #11   Ban this user!
Old 07-20-2009, 04:17 AM
Busy with Spindles for 4-th axis. Two pieces.
Yeah, its easy to do it on the paper but in real life ...
Regards,
Herbert
ID:	84708   Click image for larger version
  #12   Ban this user!
Old 07-31-2009, 10:09 AM
hi again,
Spindles I spoke about will be ready next week. Just holes and threadings leftover. Looks very nice, sad to sink in to composites.
Today at last it was possible to try Y-axis, everything seems OK.
It goes not as quick as planned, every part takes up time,
Few things have been made newly, some solutions changed.
Granite rubbles, sand, quartzitic dust and 5L of WS Epoxy while away the time ... bide their time.
Few photos show that not mach have been supervened,
Cheers,
Herbert
ID:	85333   Click image for larger version
ID:	85334   Click image for larger version
ID:	85335   Click image for larger version
WTB 5-Axis Gantry CNC Claud Want To Buy...Need help! 5 10-01-2010 02:04 AM
3 axis CNC Gantry Mill, or CNC Router Frame, Ballscrews, Linear Rails, Covers, Etc. qualitymachine EBAY ADS 4 06-02-2009 10:02 AM
My Sieg X3 Mill CNC conversion Progress replicapro Benchtop Machines 3 12-18-2008 03:33 AM
YAG-M: Yet Another Gantry mill nash Mechanical Calculations/Engineering Design 13 11-24-2006 10:38 AM
CI gantry mill i_am_fubar CNCzone Club House 0 09-13-2006 09:38 AM
