Old 07-13-2009, 10:32 PM
finishlinewrx's Avatar
finishlinewrx is on a distinguished road
Backlash Problems?
Ok first
Machine: 48x48 home built
Motors: Keling 378oz (x4) 2 on X, 1 Y, 1 Z
Driver: G540
PSU: keling 350 48v
OS: Mach3 of course
Problem is when i enable backlash comp and restart software i loose automated control.
I can jog the machine around with backlash on but wont respond to mdi command nor programed code
i can jog out to table and g28 to go home and it just clicks and sits there.
i go and unclick backlash and as soon as i click ok the machine takes off and goes home.
Theres got to be something im missing??? I have to run backlash or i would worrie about it.
Posted this in mach3 area as well with no luck thought i try here.
Nick
I Know I Cant Spell..Don't Remind Me
Old 07-14-2009, 01:20 AM
jalessi's Avatar
jalessi is on a distinguished road
Post
Finishlinewrx,
For a expeditious answer you may want to post your question on the Mach3 Forum.
http://www.machsupport.com/forum/index.php
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 07-14-2009, 01:37 AM
jalessi's Avatar
Question
What version of Mach3 are you running?
Old 07-14-2009, 10:30 AM
ger21's Avatar
What is the backlash speed percent? Also, you may need to play with the shuttle number at the top right center of General Config.
Old 07-14-2009, 11:25 AM
jalessi's Avatar
Post
There are several posts on the Mach3 Forum suggesting changing the "Shuttle Accel."
See the attached .jpg's
Jeff...
ID:	84394   Click image for larger version
Old 07-14-2009, 08:24 PM
I most likely found my problem!!
I asked the guy at work i got it from and found out he bootleg copyed it. The about mach screen says version 1.8 something and licensed to a Mr fabio.
Now i see why he gave it to me and it was on a cdr disk.
I downloaded the new version from Mach and it is way different with more features.
I have been looking around and keling has it with purchase for 149 so im going to see since i just bought a crap ton of stuff if i can still get the pricing.
Ill try the new version and see if it helps.
Nick
Backlash Problems? finishlinewrx Mach Software (ArtSoft software) 0 07-13-2009 10:42 AM
Sherline backlash problems Don-in-Japan Benchtop Machines 3 05-30-2009 04:54 PM
Problems with backlash comp Green0 Machines running Mach Software 15 07-15-2007 09:17 PM
Backlash Problems jhwatts Benchtop Machines 2 09-29-2006 06:42 PM
Ball lead screw backlash problems titchener Linear and Rotary Motion 7 09-13-2005 03:34 PM
