Old 07-12-2009, 12:10 PM
The CNC Man is on a distinguished road
What's the best router to buy for CNC?
Hello
I'm building my first CNC and I need to find a router for it, my machine is about 4ft by 4ft I'm using 80/20 to build it and I'm basically following www.pdjinc.com Pilot Pro Dual Rail CNC for the plans with a few mod's, the plans call for a Porter Cable Model # 7310, I will be using the HobbyCNC Pro Driver Board Kit and I would like to have a spindle speed control also, I'm not sure how to do the speed control yet but I need a router that will work with speed control, I will be cutting metal, aluminum, wood & plastic and any help would be appreciated.
Old 07-12-2009, 12:33 PM
jalessi's Avatar
jalessi is on a distinguished road
Post
Welcome to the Zone,
Harbor Freight has a very inexpensive speed control that works with most routers.
http://www.harborfreight.com/cpi/cta...emnumber=43060
Checkout the C6 - Variable Speed Control Board by CNC4PC
http://www.cnc4pc.com/Store/osc/prod...products_id=58
This unit can be used on many motor controllers by replacing the potentiometer that controls the speed.
A quick call or email to Arturo should confirm compatibly of the parts.
Phone:561-208-6664
email: aduncan@cnc4pc.com
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 07-12-2009, 01:23 PM
Thanks very much.
Old 07-12-2009, 01:37 PM
ger21's Avatar
Best router is probably an HSD, Perske or Columbo spindle, which will start at around $2K.
Next best is probably one of the chinese water cooled 2.2KW for $500-$600. They're speed can be controlled directly by a Gecko G540 or one of these if you're going the HobbyCNC route. http://www.cnc4pc.com/Store/osc/prod...products_id=61
A 7310 is not enough router for a 4x4 machine imo. It's too fast, too loud, and not nearly powerful enough. I'd say use at least a PC690, or the comparable hitachi that a lot of guys here have used.
Old 07-12-2009, 01:39 PM
Any preference on the router make and model
Hay
Does anyone know what router would be the best to use?
Old 07-12-2009, 01:41 PM
what's the model number on the hitachi?
Old 07-12-2009, 01:43 PM
ger21's Avatar
Amazon.com: Hitachi M12VC 2-1/4-Horsepower Variable Speed Router: Home Improvement Amazon.com: Hitachi M12VC 2-1/4-Horsepower Variable Speed Router: Home Improvement
Old 07-12-2009, 01:49 PM
emd68's Avatar
emd68 is on a distinguished road
I have heard good things about the Makita RF1101 it is a 2 1/4 HP and variable speed you can check it out at the link below.
http://www.amazon.com/Makita-RF1101-4-Horsepower-Variable-Router/dp/B00004YN3N http://www.amazon.com/Makita-RF1101-4-Horsepower-Variable-Router/dp/B00004YN3N
Old 07-12-2009, 02:11 PM
Hi
The Makita RF1101 and Hitachi M12VC both have slow start, will that matter on using a speed controller? I've noticed somethings won't work with a slow start routers! I'm going to use Mach3 software also.
Old 07-12-2009, 02:46 PM
emd68's Avatar
Both the Makita and the Hitachi are variable speed you don't need to use a speed controller with them.
  #11   Ban this user!
Old 07-12-2009, 02:57 PM
I wonted to be able to control the speed from Mach3!
  #12   Ban this user!
Old 07-12-2009, 03:10 PM
jalessi's Avatar
Question
For the 122 dollar price you cant beat it, why not just use the built in speed control?
Build Thread- Building a CNC Router; by someone who can't build a CNC Router Womble DIY-CNC Router Table Machines 2 09-27-2008 07:51 AM
Newbie- Does anyone own a EZ Router Machine? Plasma or Router. sngatlanta Commercial CNC Wood Routers 30 04-11-2008 10:48 AM
Router Using 3/4" MDF (first router build) eguy208 CNC Wood Router Project Log 33 04-11-2008 10:33 AM
Using a router for the 1st time. Need advice of cut speeds, router bits etc. Apples DIY-CNC Router Table Machines 19 09-23-2006 03:33 PM
Surfcam PP for Isel router / Precix router IvanTochev Post Processor Files 2 05-12-2004 12:27 PM
