Old 07-11-2009, 08:02 PM
analogman is on a distinguished road
Very Flat Vacuum Clamp
Hey all. I am engraving faceplates for electronics equipment. They are 3x20" on .040" material. The engraving depth is quite critical .001" tolerance.
My machine is very rigid and can do the .001" repeatability no problem, but I am having problems keeping the material flat. I have been using double sided tape, but it is not keeping the material flat enough.
So I ordered a small vacuum pump and want to construct a vacuum clamp that will keep thin material flat to .001" I asked JoeWoodworker, but he did not have any suggestions.
Any suggestions from the crowd?
thanks
Old 07-11-2009, 10:08 PM
rlwoodjr is on a distinguished road
Granite inspection table with holes drilled in it
I wonder if a granite inspection table with holes drilled in it would work. I think you can buy these in different sizes.
Old 07-11-2009, 11:18 PM
Are all the faceplates the same size?
If the answer is yes simply make a vacuum base out of aluminum; actually two pieces of aluminum.
Machine a labyrinth in the two pieces and fasten them together. Tap a hole for the vacuum line so it intersects the labyrinth.
Bolt the two plates securely on the machine table and machine a shallow pocket to take your faceplates.
Around the perimeter of the pocket mill a small groove to take a length of soft O-ring cord.
Drill many holes in the pocket to intersect the labyrinth between the two plates.
Put your faceplates in the pocket and apply vacuum; they are going to be held as accurately level as you machined the bottom of the pocket.
Old 07-12-2009, 12:35 AM
That sounds like it will work Geof - thanks!
Old 07-12-2009, 10:07 AM
bsdphk is on a distinguished road
You may be able to use the same trick I use for pcb's, probe the height and let the G-code interpolate the correct Z:
http://phk.freebsd.dk/CncPcb/
Poul-Henning
Need Help!- Building Vacuum Clamp and Mechanical Clamp Sub-Table automizer DIY-CNC Router Table Machines 11 04-27-2012 12:46 PM
Lathe Bed: how flat is flat enough? Donkey Hotey Haas Lathes 25 05-17-2010 02:35 PM
100% flat table for flat bed lamination Bernhardsen Printing, Scanners, Vinyl cutting and Plotters 4 08-24-2008 08:31 AM
Need Help!- Building Vacuum Clamp and Mechanical Clamp Sub-Table automizer Work Fixtures and Hold-Down Solutions 0 04-07-2008 09:05 PM
Build cnc router without linear ball bearings ?? Flat metal on flat metal with lube ? vroemm Linear and Rotary Motion 7 08-16-2007 12:26 PM
