Old 07-11-2009, 02:26 PM
eloid is on a distinguished road
limit switch as home switches
can some please post a how too..note to configure /
to emulate home switches... i think i have a bad one
and replace it yet.. what required for software setup?
Old 07-11-2009, 02:49 PM
Bubba's Avatar
Bubba is on a distinguished road
What controller/BOB setup????
Art
Old 07-11-2009, 03:01 PM
jalessi's Avatar
jalessi is on a distinguished road
Post
Eloid,
Change the status to green for the desired axis.
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 07-11-2009, 03:27 PM
ger21's Avatar
I don't think you want to emulate them. You just want to assign them to the same pin. If your X- limit will be your home switch, just set them both to the same pin.
See 5.3.3 for emulated inputs.
http://www.machsupport.com/docs/Mach...all_Config.pdf
Old 07-11-2009, 03:31 PM
jalessi's Avatar
Post
Gerry,
He may have existing switches wired in series, if so he may need to emulate it or jumper it out.
Jeff...
Old 07-11-2009, 04:08 PM
the bob is cnc4pc c23
all the limit switchs are in series
had seperate home switch wired for each axis.
orginally i thought it was a switch bouce issue
I have since replaced the switch and still get the same problem
what i am finding is the when Y home switch is depress by machine or hand
the home 2 led will flicker on diagnostic page in mach... like is debounceing
even when u depress the switch fully by hand and hold it... this lead me to think its not a switch bounce problem.... I dont think its the switch, I checked the solding to micro switch it ok, checked all the leads and quick connectors between machine and bob.... even resliced them.... everthing beeps when cable stressed?
Old 07-11-2009, 04:46 PM
abnormal condition button flashing
my machine is a fix gantery type y axis moving table. I Had this
question to ask...
In mach i get yellow abnormal condition button flashing....
it notes axis are not refed to normal condtion.
im thinking this cus the way....the limit and direction of movingment is set up for the y axis for the moving table?
Old 07-11-2009, 06:52 PM
jalessi's Avatar
Post
Eloid,
Check for cold solder joints on the breakout board.
We have had a few boards with bad solder joints.
Look at the board under magnification.
Jeff...
Old 07-11-2009, 07:01 PM
cold solder joints
will do that .... need to remove all those wires again
Old 07-11-2009, 08:00 PM
hoping someone can shed some light on this other problem i have with my limits and homeing set up mach....
below is a very simple top down drawing of my fix gantery cnc,
when load g code i would like the cross hairs to appear as in my drawing
and want the x,yx 0,0,0 to be located as per the drawing
I guess i need some help setting up the soft min, max values to display
as per the drawing.
Name:	TOP DOWN VIEW CNC.jpg‎
ID:	84264   Click image for larger version
Old 07-11-2009, 08:27 PM
ger21's Avatar
If you want your 0,0 to be upper right, then all your X and Y moves need to be negative coordinates. Your mins would be -18 and -15.75, and the max would be 0.
  #12   Ban this user!
Old 07-11-2009, 10:46 PM
thanks ger21
as of now emulating the home switch....untill i worked out all other bugs will look into that tip....thanks jalessi
limit switch and home switch setup Runner4404spd General Electronics Discussion 0 12-15-2005 07:58 AM
The relationship of limit switches to home switches. MikeAber General Electronics Discussion 4 11-04-2004 01:28 PM
Limit Switch / Home Switch in Software Sanghera General Electronics Discussion 6 11-01-2004 05:58 PM
Home switches and limit switches. ynneb General Electronics Discussion 5 04-08-2004 05:32 PM
