Old 07-09-2009, 07:57 PM
Gold Member
mlaws1172 is on a distinguished road
DIY flex metal echain
If you have more time than money, here is a way to make your own wire carrier.
It doesnt require any welding and you can print out - stick to metal and use for template to cut
The bending directions are on the pages
mike
Name:	MIKES PICTURES 265.jpg‎
Old 07-09-2009, 10:33 PM
FandZ's Avatar
FandZ is on a distinguished road
Very cool indeed, thank you for posting.
Old 07-10-2009, 05:44 AM
CarveOne is on a distinguished road
Thanks!
Looks like this could also be made from aluminum sheet on a CNC router as well.
What does "HEM" refer to?
CarveOne
CarveOne
Resistance is not futile. It is voltage divided by current (R=V/I).
Old 07-10-2009, 10:19 AM
randyf1965 is on a distinguished road
I would assume it refers to the folded edge... like the hem on a pair of pants. Rounds off the sharp cut edge
Old 07-10-2009, 12:45 PM
Weldtutor's Avatar
Weldtutor is on a distinguished road
Arrow Wire Carrier
Nice design Mike!
Old 07-10-2009, 01:21 PM
Gold Member
Yes, just like a pair of pants, it rounds out the edges and it is what locks it togethor.
If there is interest i will post the cad files in dfx and takes some pictures of how it goes togethor.
It could use a little more tweaking but I dont have time right now.
Aluminum would be a great materal to use. I used 26 ga. galv. sheetmetal.
The rods are 8-32 althread cut to lenght and the spacers 1/8" plastic tubing.
Nice to hear from you Bruce.
Mike
Old 07-10-2009, 06:28 PM
Bubba's Avatar
Bubba is on a distinguished road
Mike,
Sure would appreciate the additional information at your convince:})
Thanks in Advance.
Art
Old 07-10-2009, 07:11 PM
Mike
Yes, the DXF files would be very welcome indeed. I would think that sheet ABS plastic could be formed well enough if a little heat is used at the bend lines. Designing this for sheet stock allows many different materials to be tried.
Thanks again,
CarveOne
CarveOne
Old 07-15-2009, 06:26 PM
Gold Member
Here is the DFX drawings - I have modified the top and bottom to make them easier to bend
Mike
Old 07-15-2009, 06:38 PM
Bubba's Avatar
Thank YOU!
Art
  #11   Ban this user!
Old 07-15-2009, 06:55 PM
Thanks very much for your efforts Mike. I will make use of this.
CarveOne
CarveOne
  #12   Ban this user!
Old 07-16-2009, 08:12 AM
Alexthehun is on a distinguished road
Thanks Mike
Just what I was looking for!
G0602 Flex rwskinner General Metal Working Machines 0 01-22-2009 06:58 AM
Flex Coupler Jerry In Maine Want To Buy...Need help! 2 02-20-2008 03:41 PM
steel rod flex erase42 Mechanical Calculations/Engineering Design 5 01-24-2007 03:04 AM
flex coupler runswithscissor CNCzone Club House 2 12-08-2005 12:12 AM
Flex Couplings drk Linear and Rotary Motion 10 10-29-2005 11:01 PM
