Thanks to Ahren (www.cncrouterparts.com ) who sent me a couple of pieces of 1/2-10 5. I milled 4 flutes 3/16" wide and 0.1" deep, then tapered the end. The plastic has a .445" hole drilled into it |
Here is a short movie file showing the results. The tap is around 6" long. I think I will make one around 12" long. The process: I put it in my cordless drill and went forward then reverse until it broke through, then I did it a couple more times. |
| Glad to see it worked out for you! So what now? Are you planning on building a machine? Need any bearing blocks or linear motion components to go with your new drive nut? ![]() Ahren www.cncrouterparts.com |
then I am making him a 2 axis for a small wood lathe, then I am making mine so I have quite awhile before I will start on it. I Thanks again for the samples...I will have to save some cash to buy some of these acme screws. Last edited by rlwoodjr; 07-11-2009 at 02:24 PM. |
| I was also thinking about freezing the plastic to make it more rigid. |
| fanuc 6M -the start key does not works | mehrdad | Fanuc | 1 | 09-13-2007 03:42 PM |
| start of a good project | mastermoparman | Vertical Mill, Lathe Project Log | 7 | 06-13-2007 01:36 PM |
| IS Bobcad V19 a good program to start | Biggermens | General CAM Discussion | 15 | 10-29-2004 09:46 PM |
| Single line mode works well, Auto is not soo good?? | Darc | CamSoft Products | 16 | 10-26-2004 03:29 PM |
| Where is a good place to start? | Binow | DIY-CNC Router Table Machines | 1 | 07-16-2004 02:52 PM |
