| I used LoveJoy brand "spider type" on mine. when i asked i got a couple different options. I didnt use soild ones due to not allowing much if any misalignment. Just my preferance though. http://www.cnczone.com/forums/showthread.php?t=78976 Here is what they told me ^^
__________________ Nick I Know I Cant Spell..Don't Remind Me |
| Oldham couplings seem to be the way to go and I will be using one on my X axis but they are not cheap. Zero backlash is what I am after. For 12 Nm the chart says that a unit at 41 mm has a rated torque of 14.8 Nm. The next size down is 33mm but only has a rated torque of 8 Nm when using an Acetal center disc. http://docs-asia.electrocomponents.c...6b80020553.pdf I also wanted to use solid couplings but was convinced away from doing that by very cluey people here. That being said some have run their machine for years with solid but have also heard that some have snapped the motor shaft clean off after running slightly out of alignment. Cheers M
__________________ No, Little-Johnny, pomegranate is not a type of English stone. |
| I'm useing spider couplings now but on my next build I think I'm going to try out these nifty K-couplings. http://www.beemerprecision.com/kcoupling.asp Searching around there are different verities between $10 to $30 depending on the size. Reading up on them, they allow for some miss alignment and have good vibration dampening. Zero backlash. They just look slick. |
| When I say aligned, I mean both radially and along the axis. It is my opinion that this would be hard to get correct on a DIY machine. You could use a rigid mount and soft mount the stepper motor. |
| End Supports and Couplings | geometrix | Linear and Rotary Motion | 1 | 05-08-2008 05:14 PM |
| Design Question: About Lovejoy (Spider) Couplings | Odin | Mechanical Calculations/Engineering Design | 9 | 04-24-2007 10:49 PM |
| Question on couplings | studysession | DIY-CNC Router Table Machines | 31 | 08-18-2006 12:22 PM |
| Looking for Beam Couplings | Robyn | Mechanical Calculations/Engineering Design | 2 | 03-24-2006 06:40 AM |
| Flex Couplings | drk | Linear and Rotary Motion | 10 | 10-29-2005 11:01 PM |
