Hi, would like to know how do you home your 4th Axis. I'm not sure if a limit switch could be fine tuning enough to get good result. I'm not sure either with an infrared device like a spindle indexer. So how do you get good result when zeroing your 4th Axis. Thanks, Jeff |
| If you mount an encoder on the motor, you should be able to home using a combination of the limit switch triggering, to then begin a 'find index' routine to find the encoder marker pulse. If you want to do this manually, I suppose you could drill and bore a small hole in the edge of the table platter. Then use a dial indicator to sweep to find the hole center after you have already centered the table under the spindle. Then, command a G92 A0 to zero that axis.
| hi again, Sad not any good ideas about ![]() Anyway - How to zero a rotary axis, Look at this Protractor: MINI DIGITAL PROTRACTOR INCLINOMETER ANGLE FINDER GAUGE | eBay How it works ??? Perhaps could be used for zeroing rotary axis when base of machine is well levelled Hopfully there is possible to get signal output ( or not ???)For this idea the main problem for me is that machine itself must to be accurate levelled ... my machine need to be a little bid inclined for coolant drainage Any more ideas? I do not believe any limit switches can find precise zero ... vertical or horisontal ...or what ![]() Yes, when zero once found then rotary decoder does the rest during all the work but specifically this first perfect zero finding before each work - this is very boring at least for me. cheers, herbert |
| Herbert- Have a look at this thread; http://www.cnczone.com/forums/open_s...made_easy.html It shows some simple home switches that will measure to about 0.01mm, and also have the advantage that they can "slide by" the zero point so they will not interfere with continuous rotation. And they have no moving parts to wear out. I have these home switches on my machine and they are so accurate I can see tiny changes caused by the machine warming up and expanding. |
| A 5-axis CNC machine including a rotary axis | synthetiklone | CNC Wood Router Project Log | 11 | 05-23-2012 09:31 PM |
| rotary type 4th axis | mocnc | DIY-CNC Router Table Machines | 59 | 10-26-2008 06:55 PM |
| CNC Rotary Axis help:-( | YANKS_RINKS | Mastercam | 4 | 06-10-2008 05:58 PM |
| Dro on a rotary axis. | Smackre | DIY-CNC Router Table Machines | 7 | 01-16-2007 07:45 AM |
| 4 Axis Rotary | Smackre | Mastercam | 3 | 08-09-2006 11:28 AM |
