Does anyone have experience using 1" PVC sheet stock for a vacuum plenum? I'd like to try using it to make a master vacuum bed with 1/4-20 threaded inserts and dowel pins for locating and bolting jigs. I'm just concerned with the wearability. |
| You do not mention any sizes or what type of work will be done. MDF or plywood could be possibilities but not if you are using coolant. Aluminum is probably the best for ease of making it, strength and lightweight but it would be expensive for a large plenum.
| I was originally thinking of covering my 48" x 48" table, but I think I'll scale down the plenum size to 40" x 20" which is doable cash-wise using 5/8" thick cast aluminum. That will cover 90% of my needs. |
Poly is probably cheaper than aluminum. I was thinking of using it on my build. |
| Vacuum table and vacuum pump | garagefela | DIY-CNC Router Table Machines | 19 | 01-25-2012 10:30 AM |
| "low end" HF Spindle or "high end" router for about $1000? | biomed_eng | DIY-CNC Router Table Machines | 14 | 01-06-2012 12:15 AM |
| BattleAxe "aka" Ball and Chain "aka" the wife. | ZipSnipe | CNCzone Club House | 48 | 05-18-2008 09:53 AM |
| Has anyone looked at the "JET" or "Shop Fox" manual machines? | boosted | General Metal Working Machines | 12 | 03-04-2007 09:33 PM |
| Cast aluminum Runners and Plenum | Kmed | Employment Opportunity | 3 | 08-30-2005 11:35 PM |
