Old 06-30-2009, 10:28 PM
Realmseeker is on a distinguished road
Recommissioning a semi-used diy-cnc
Hey all,
I was on the verge of building my own CNC based off of Joe's plans, but stumbled onto a machine on Kijiji at a good price. The only problem with it is that it lacks the BOB/controllers. The basic story is that the gentleman that built died, and I bought it from his son. He couldn't find the original controllers. So basically I am hoping you guys can help me pick a controller to use with this machine.
My uses will be to use it on solids and some mdf/PB. It has a small ryobi router in it but I will need to replace the entire plate it sits on to put in a new router as its coupler is braised to the plate.
So I guess pictures are in order. I really do not have a lot of information on the build or what parts are made of. I am hoping that the community can help me identify a few of the parts.
The 3 motors are 'japan servo co kp86sm2-002'
http://www.used-line.com/c6120527s10...vo_KP86SM2.htm
They are 4 wire motors. The X and Y are belt driven with gears. Anyone need me to count teeth and give the diameters of the gears? The Z is connected by a lovejoy.
The transformer just has a serial code on it. I tried googling it, no luck. Would the power of it be marked?
I'll also post a pick of the screw with a tape measure. It took me a little bit more then 5 turns(very little) to move the Z 1". I am fairly certain these are acme lead screws, but there seems to be a small groove along the centre of the thread.
So pics! the base is 3'x3' with 5"-6" for the Z.
Please request anymore pics that are not in this post. I'll give you the best information I can. I wanted to get a HobbyCNC controller, but that is only for unipolar 5,6, or 8 wire motors. Can I do a Gekco? I am also considering using a design off of Pmino's website, but I cannot tell which board to pick. I know I would need a bipolar one, but I am always confused by which one would suit me best. Also as too how much voltage I need.
Old 06-30-2009, 11:15 PM
Forgot too add:
the original drivers were going to be:
cy-42c cyberpak
http://www.cyberpakco.com/cypk_cy-42c.html
He had some cy-45 lying around, but I did not know if they were good or suited the machine. I think the cy-45 are old tech.
Old 04-15-2011, 02:24 PM
campet is on a distinguished road
CY -45
I think I have the same machine as you have...I got this machine from kijiji
at a bargain price...CY-45 are working amazingly at rapids of 400 ipm.
My plan is to use the machine for parts and construct a metal welded frame as a stronger base...I will be glad if you sent me some pic of the machine ....I promise I will do the same...
Semi-rigid tapping on SX3 presslab Syil Products 0 02-22-2008 01:22 PM
Semi Automate a Spindle racear*2865 Stepper Motors and Drives 14 08-02-2007 12:35 PM
Help me decide -- MTC Semi-Pro or Ez-Router Hyrum R Commercial CNC Wood Routers 16 04-23-2007 06:46 PM
Looking for semi-cheap CAD software Burn General CAM Discussion 16 05-22-2006 04:34 AM
Semi-automatic oiler ozzie34231 General Metalwork Discussion 2 02-18-2006 12:29 PM
