Old 02-14-2005, 07:55 AM
Wanna be
Hack is on a distinguished road
Need cheap source for acme lead screw parts
I am looking at using some acme lead screws to replace the all thread on the machine that I am currently building. While the threaded rod is cheap enough, the end bearings are not (I see them for up around $200 each).
Does anyone know of a source for these ends at a cheaper price? I want something new and not Ebay - as this needs to be a fixed repeatable price.
Better yet, does someone know of where I can buy a ready to install unit with the end bearings, ball nut and rod ready to install? Looking for a 48", a 36" and a 10 - 12" unit.
Thanks all
Check out what I am working on at www.routerbitz.com!
Old 02-14-2005, 08:41 AM
ger21's Avatar
Thanks all
I doubt you'll find them any cheaper. I think the reason they are so expensive is that they use expensive angular contact bearings. If you need a lot of them, you might be able to have some made using cheaper bearings, maybe even rollerblade bearings. Post in the reques for quote forum and see what kind of price you can get them for.
I believe you can purchase complete assemblies from McMaster-Carr. Bring your wallet.
Old 02-14-2005, 10:45 AM
jcc3inc is on a distinguished road
Hack,
It wasn't completely clear to me just what you wanted, but a good source of acme thread screws and nuts is Green Bay Mfg. Co., 920-793-2411, FAX 920-793-4848. They range from .375 -12 to 2.0" -4.
Hope this helps,
Jack C.
Old 02-15-2005, 10:34 PM
2muchstuff is on a distinguished road
A while back I spoke to a garage door/ opener installer about acme lead screws used in door openers. They either come in 3 foot 6 inch or the full 7 foot sections. They throw the old openers in the trash. Food for thought.
Old 02-16-2005, 09:06 PM
Wanna be
Suitable Replacement / Substitution?
Is it possible to use a flanged bearing such as a "Flanged Mount Ball Bearings" from McMaster Carr as a suitable substitution? ( Ex. Part #5967K52 )
Old 02-22-2005, 12:10 PM
pen25 is on a distinguished road
I just found this site.. pretty decent prices seems like www.wttool.com whats nice is they have a local store
Lead screw whip spalm DIY-CNC Router Table Machines 3 05-24-2005 03:04 PM
One lead screw off-centered..Will it work? bgolash DIY-CNC Router Table Machines 14 04-02-2005 09:57 AM
Alternate Lead Screw Mounting Idea Jay C Mechanical Calculations/Engineering Design 4 02-20-2005 02:32 PM
How to machine a 56 Rockwell lead screw bgolash General Metalwork Discussion 6 12-05-2004 04:25 AM
Cheap UK Lead Screw, but is it any good? MrBean DIY-CNC Router Table Machines 3 02-15-2004 01:59 AM
