Old 06-28-2009, 09:10 PM
analogman is on a distinguished road
DIY Mister for DIY CNC Router?
Hey all, about half the work I do with my CNC is routering aluminum sheet (.080"). I would like to use some form of coolant so bits last longer and I get a better cut. Sure I can use WD40, but its a PIA to stand there while the sheets are cut.
Anyone have a simple easy solution for a mister?
thanks
Old 06-28-2009, 10:17 PM
FandZ's Avatar
FandZ is on a distinguished road
I've been thinking about this one. In drug stores they sell water picks that have good veritable power settings for around 20 bucks. It would take some modding but I'm sure one could be rigged to hold enough cutting fluid to fit our needs.
I'm not at the point where I would need a mister so I haven't really looked into it yet. It's just something hanging around the back of mind for later.
Old 07-06-2009, 03:40 PM
aleccoh is on a distinguished road
Smile wanna cut staianless sheet without the PIA wd40?
just use DRY a 1.5 mm carbide 2 flutes end mill
NEVER try to erode the sheet because it will bend and make the end mill go to hell
just plunge and DRAG CUT
Feed : 80 mm/mn
spindle : 6000 rpm
and a 1 mm stainless sheet will cut like BUTTER (aluminum too of course)
have fun
Old 07-06-2009, 07:00 PM
Regnar's Avatar
Regnar is on a distinguished road
Over in the mill section one used a Chemical mister that you get at walmart to spray bug killer and weed killer. Holds 3 gallons and doesnt require power or compressor. Just need to pump it up a couple of times and adjust spray settings.
Old 07-07-2009, 11:25 AM
pminmo's Avatar
pminmo is on a distinguished road
I've toyed with the idea. When cutting aluminum .063 sheet with a wood router (20K) I use denatured alcohol in a squirt bottle, it keeps the aluminum from melting and adhearing to the cutter and evaporates so there is no residue. Constant monitoring is a pain, so I'll watch this thread and see if any cheap solutions come from this group of out of the box thinkers.........
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 07-07-2009, 12:34 PM
KIMFAB's Avatar
KIMFAB is on a distinguished road
I cut 6061 on my Shizouka and use a straight air jet- works fine. Just tie the nozzle next to the cutter.
I used to be appalled, now I'm just amused.
Cheap & dirty mister setup MechanoMan Benchtop Machines 4 05-25-2009 12:00 PM
Mister Mooser Tormach PCNC 0 06-01-2008 09:21 AM
Need Help!- SMC LMC200 mister problem lannyn General Metalwork Discussion 0 03-15-2008 07:18 PM
NASA gear bearing by mister Vranish wolphje General Metalwork Discussion 1 07-28-2005 01:28 PM
Mister cooling?? Robin General Metalwork Discussion 1 04-11-2005 08:59 AM
