hey. this is my second post, i hope i get as good a response as i did on the first one. OK, i found some cool stepper motors that i hope to use. they are SUPERIOR SLO-SYN type MO92-FD-8104, HOLD 300 oz/in, 200 steps/rev, 5.8 volts @ 2 amps. i read a post that said i should connect (its an 8-wire motor) it for parallel windings for best torque/speed. but how do i know how much driver i need? is a driver rated at 3.5 amps enough? i plan to run them on a 24VDC power supply, and i know it controlls the current, but do i set the limiting resistor for the 2 amps, or is there a formula( there are lots of formulas i'm begining to realize) and i need to pencil some things out? what is the deal with the henries(inductance) of the motor? i had hoped to use the GECKO G540 drives for this, its a nice package and pretty simple,cost effective. will this work ? im not asking for someone to do all the work, but if there is a post or web-page you can point me to to figure it all out...thanks! |
| Surfjunkie, If the motors are rated at 2 amps, set the drivers for 2 amps. A 2K set resistor will be required for each axis. You will not get very good performance with a 24 volt power supply and those motors. The old round motors like higher voltage, use at least 48 volts. Jeff...
__________________ Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish. |
| Surfjunkie, I would run 48 volts or more with new as well as the older models. Stepper speed is directly effected by voltage. The new motors are a lot more efficient though. Jeff...
| The 2A rating is in all likelyhood the phase rating. In parallel it would be 1.4 the phase rating or 2.8A maximum. http://pminmo.com/PMinMOwiki/index.p...le=8wiremotors
__________________ Phil, Still too many interests, too many projects, and not enough time!!!!!!!! Vist my websites - http://pminmo.com & http://millpcbs.com |
| Problem- Stepper motors are getting too hot!!! | ryansuperbee | Benchtop Machines | 13 | 07-28-2008 06:22 AM |
| Wanted DIY stepper driver circuit for 6 wire stepper motors | Colin300 | Australia, New Zealand Club house | 5 | 09-20-2007 09:20 PM |
| stepper motors or servo motors? | jprobst | Torchmate | 3 | 07-13-2007 05:37 PM |
| Are these stepper motors big enough | andrewbishop66 | Bridgeport and Hardinge Mills | 4 | 02-04-2007 11:31 AM |
| Stepper Motors | tinwakr | Stepper Motors and Drives | 1 | 10-29-2004 03:43 PM |
