| My X axis has two motors X and A (slaved). It seems that the A side is lagging a miniscule amount causing the machine to vibrate. Is there a way to test how much it is lagging by? Thanks, Matt |
| Have you tried "swapping"the wires from the controllers to the motors? If it does it -- opposite(ly) maybe a set up problem -- If still the same (A side) I'd guess the motor. That won't get you to testing the Lag - but will confirm that it is a motor problem and not a steup in the software. (Also, it might point to a physical binding on the "Ä" side.) Hope that gets you a start - surely others will have a good idea or 2 as well. Cheers - Jim
__________________ Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it. |
| ^^This My slaved axis prob done close to the same thing. One was slower to take off than the other. Ended up being a bad soilder joint in the motor plug and not anything with the software.
__________________ Nick I Know I Cant Spell..Don't Remind Me |
| screw mapping with slaved axis | multiplex | Mach Software (ArtSoft software) | 0 | 05-15-2009 09:32 AM |
| Need Help!- Adding a slaved X axis | t140nick | Mach Software (ArtSoft software) | 4 | 02-05-2009 02:05 AM |
| Need emergency help. Slaved Y still binding.. | nate | DIY-CNC Router Table Machines | 2 | 03-05-2008 06:59 PM |
| Slaved Motors Pros & Cons | destro | CNC Plasma and Waterjet Machines | 5 | 07-17-2006 09:28 PM |
| slaved motors aren't working in synch | axisdd | DIY-CNC Router Table Machines | 2 | 03-15-2006 01:59 PM |
