Old 06-22-2009, 08:01 AM
satguy is on a distinguished road
Urgent help!! is this belt ok?
Im just about to put an order with stock drive.
can someone please tell me if this belt:
https://sdp-si.com/ss/PDF/79002051.pdf
is ok to use with a XL 15 teeth pulley. The thing im not sure about is that the belt is reinforced by fiberglass. All the literature that i have read sais that fiberglass belts are not good for small pulleys. But they dont tell you how small is small?
is a XL 15 teeth pulley considered too small for this belt?
please help. i cant find the answer anywhere
Old 06-22-2009, 11:19 AM
ger21's Avatar
According to this it's fine. Page T-41 (last page)
http://www.sdp-si.com/D265/HTML/D265T016.html
Urgent question!!minimum pulley size and belt type? satguy Linear and Rotary Motion 1 06-22-2009 09:05 AM
Need Sherline Belt & qestion on X2 Belt Drive? Oldboy Benchtop Machines 12 03-06-2008 01:42 AM
Belt size/spec for Sieg X3 driving belt rashid11 X3/SX3/G0619/G0463 0 02-10-2007 08:01 AM
Seeking Belt Sander Belt Source 6 x 48 Dugg General Metal Working Machines 3 12-24-2006 10:48 AM
URGENT: 2J Quill return sping replacement -URGENT NC Cams Bridgeport and Hardinge Mills 8 02-13-2006 11:48 PM
