Old 06-21-2009, 11:08 AM
analogman is on a distinguished road
Chinese Spindle - using the control panel
Hey all, when my huanyang VFD and spindle is running, I am able to toggle the display from Frequency to Current to RPM by pressing the ">>" (shift) key. Cool.
I can adjust the speed of the spindle by pressing the up/down arrows, then select the digit with the ">>" key, then press the up down arrows for the value. BUT when I adjust the speed it is always in frequency, NOT RPM.
Anyway I can get it so when I adjust the speed, I adjust it in RPM?
thanks
Chinese Spindle - which control board? analogman DIY-CNC Router Table Machines 3 05-17-2009 01:34 PM
Control panel faces DrStein99 General Electronics Discussion 5 09-24-2008 02:00 PM
Control Panel Cut out scruffyjones48 Employment Opportunity 5 08-03-2008 04:47 PM
Problem- Versalaser Control Panel Vice Laser Engraving & Cutting Machines 0 02-22-2008 04:15 PM
My DIY control panel DennisCNC CNCzone Club House 6 10-02-2006 11:24 PM
