I have modified turbocnc to: jog with dual X axis using Left/Right keys. use the * key for fast jog so I can use the numeric pad for jogging Also, my HobbyCNC board has a power reduction feature modification (see link) Current Reduction, HobbyCNC - Mach3 What I am going to try to modify turbocnc to reduce power when motors are not active for a set period of time. |
| Dear rlwoodjr: Beautiful machine - very elegant design and proportions - great craftsmanship - Congratulations! Would love to see more details: type and size of rods and bushings, screws and nuts; is it all aluminum? Nelson |
| All the linear rails are 3/4", the X has an extra middle support. Bearings are Thomson. The screw drives are 5/8" ACME and 8 threads per inch. The nuts are UHMWPE (Polyethylene, Ultra High Molecular Weight) plastic material. Cut with a tap made from the threaded ACME rod. Frame is all aluminum on an MDF frame. I still need to add the YZ cable track and the home and limit switches. I also have a 4th axis (rotary) that I am going to add. So I still have lots to do.. |
I made an adapter plate so I could attach the stepper to the harmonic drive. Harmonic drive is 50:1 The metal behind the chuck is a bearing...need to make a mount for it. Last edited by rlwoodjr; 06-19-2009 at 06:54 PM. |
#11
Is that a reduction drive on your 4th axis motor? I am running thru ideas on how to make one of these, and that looks like a very simple method. Where did you find that one? Jon |
#12
| It is a 50:1 harmonic drive. I bought a couple of these on Ebay. They do not have any backlash so it seems like a good idea. I have not made anything yet, but its my next project. I am using GMAX and the CNCtool kit so I have a learning curve. I had to make an adapter plate...pretty easy when you have a cnc mill. |
| Newbie - To build or not to build Router/Plasma Table | dfranks | CNC Plasma and Waterjet Machines | 10 | 04-08-2011 12:16 AM |
| NEW BUILD: PVC as a build material | Smiler | DIY-CNC Router Table Machines | 12 | 11-13-2009 05:57 PM |
| New Large Table Build in Houston, TX (Build Log) | anitel | Plasma, EDM and other similar machine Project Log | 12 | 12-30-2008 03:45 AM |
| Need Help!- Which to build, which to buy? | glintid | DIY-CNC Router Table Machines | 7 | 07-24-2008 09:05 PM |
