Old 06-16-2009, 09:46 PM
eloid is on a distinguished road
?? 4 fix gantry designs
have a question about fix gantry designs
ie moving tables, the home switch needs to be set up a little differently....
so x, z home is over y home just like a moving gantry but
the home is tripped to back of the table... so x,y,z are all on top
of the same location... else y is homed to the front of x,z the distance of the table away fom the gantry.?
Old 06-18-2009, 08:19 PM
TLHarrell is on a distinguished road
Essentially, all setups of home and limit switches are identical mechanically. They go near the end of travel of your axis. How you physically trip the switch is up to your application. In the case of a traveling table, I'd suggest that the home location be set with the table farthest forward on the machine, with the cutter at the back edge. The machine I used to program on was set that way. Y axis on the gantry would home to the right side, where the control station was, and Z was with the tool plate raised all the way. This facilitates easy table loading and tool changes.
looking for designs justin22885 Musical Instrument Design & Construction 25 02-27-2009 04:00 PM
Where can I buy plastic designs from? noac Glass, Plastic and Stone 5 03-06-2007 02:30 AM
H bridge designs R.thayer General Electronics Discussion 5 02-15-2007 02:06 PM
Q: Y Axis - Gantry vs. "bridge" designs Zoid DIY-CNC Router Table Machines 9 07-06-2004 05:35 PM
r,theta,z VS x,y,z designs. cnczane DIY-CNC Router Table Machines 8 02-18-2004 10:09 AM
