Designing a gantry system, but no experience doing one before, so looking for general info. I'd appreciate any thoughts you have on these... (1) For a light duty, but high precision application, what are the pros cons of the following gantry styles: (a) Y axis has 2 linear rails or shafts/pillow blocks, but only one side is driven. (b) Y axis has 2 linear rails or shafts/pillow blocks, but both sides are driven. (c) Y axis has 2 linear rails or shafts/pillow blocks, but center driven. I expect the answer will involve racking, but not sure how relevent it is for a light duty application. (2) Why would I choose linear rails over shafts/pillow blocks? Suprisingly I can't much on this comparison here or via Google. Also, I've seen some designs that use bearings mounted at "triangulated" angles against a shaft. Any good for precision use? (3) Over a 2-ft run, what diameter of shaft should I use? Or should I use something small but continuousl supported ? Thanks, -Neil. |
| 1) a and c would depend on the rigidity of the gantry. b takes that out of the equation. 2)Linear rails are smoother, and can carry heavier loads. 3) Supported is a must. 1/2" should be adequate.
| X3 conversion design options.... | Matt McColley | Benchtop Machines | 2 | 01-31-2009 05:48 PM |
| New design, gantry or something else | Miguel- | General Metal Working Machines | 0 | 01-26-2009 04:33 AM |
| GANTRY Design | bert5604 | CNC Plasma and Waterjet Machines | 3 | 10-01-2007 09:30 AM |
| Haas Gantry Router dust exraction options | CJH | Haas Mills | 16 | 06-20-2007 07:44 AM |
| Gantry design??? | dmgdesigns | DIY-CNC Router Table Machines | 1 | 05-25-2004 10:13 AM |
