Old 06-15-2009, 09:12 AM
satguy is on a distinguished road
pulley bore size question
I have a nema 17 motor which according to lin engineering (the maker) has a shaft diameter of 0.1968 inch. This is according to my calculations is 4.998mm in metric.
if the pulley i order has a bore hole of 5mm. will these two parts fit? if not what size bore should i order?
sorry if this is a stupid question. this is the first time im ordering pulleys
thanks
EDIT: also is a hubbed pulley better in terms of gripping the shaft better?
Old 06-15-2009, 09:21 AM
mactec54 is on a distinguished road
Hi satguy
Yes the 5mm will be good
Mactec54
Old 06-15-2009, 11:40 AM
Hirudin's Avatar
Hirudin is on a distinguished road
I have heard that hubbed pulleys are for shafts that are completely round and pulleys with set screws are better for shafts that have a flat.
Old 06-16-2009, 01:16 AM
mc-motorsports's Avatar
mc-motorsports is on a distinguished road
Yes, your 5mm ID pully will more than likely have a ++ tolerance. And as mentioned above, grind a flat in the shaft for the set-screw, works for me.
MC
Boss 6 Motor Pulley Options - 5/8" to 1/2" Bore snakebit95 Bridgeport and Hardinge Mills 0 08-11-2006 03:03 PM
Boss5 Pulley & Belts Size - Verify PeteW Bridgeport and Hardinge Mills 18 07-22-2006 09:58 PM
Speeds for cutting metals relating to pulley size? ZipSnipe Mechanical Calculations/Engineering Design 2 06-15-2006 09:11 PM
Pulley question... WilliamD Autodesk Software (Autocad, Inventor etc) 4 06-05-2006 08:37 PM
Timing Pulley - Plain Bore or Keyed ViperTX Mechanical Calculations/Engineering Design 3 11-26-2005 11:24 PM
