Old 06-14-2009, 05:21 PM
revwarguy's Avatar
revwarguy is on a distinguished road
It's alive and kicking!!
My CNC table is getting there
I tried to link to a you tube movie here, but I couldn't figure out how. If you goto
www.liming.org/cnc
and scroll to the bottom of page 4, you can see the movie there.
Now, I need to get a better router and cut something!
Old 06-14-2009, 05:27 PM
MrWild is on a distinguished road
This mlink sbhould work for you.
http://www.youtube.com/swf/l.swf?iur...l=&cr=US&eurl=
Old 06-14-2009, 05:48 PM
revwarguy's Avatar
It's alive (the movie)
Ok, lets try this one...
Thanks, I was trying to make it too hard. Understand, this movie was made for complete newbies
(like myself) who don't yet know the terminology.
Old 06-16-2009, 12:06 AM
sonicwonder2000 is on a distinguished road
Very inspiring build! I read through your entire site and it seems that you are an electrical engineer? I loved your build details and the way you configured the gantry z-rails (I might have to steal that from you ).
Get rid of the hf router - like putting a $5 spray-can paint job on a ferrari - your build deserves a nice router. I hope mine turns out as well. Congrats!
Old 06-16-2009, 03:42 PM
revwarguy's Avatar
router
Well, the HF router is one I had on hand - you're right. Thinking about a Bosch Colt - any thoughts? (a refurb for $75 on amazon!) The real problem is the design for the router mount - I am thinking about two Vee shaped pieces clamping together, or something else.
I am very happy with the design of table otherwise. I've noticed that while executing an actual gcode program, the whole table has a tendancy to wobble and shake just a bit from the movement of the gantry and carriage. I am thinking of some side bracing, or even attaching a corner to a floor joist support pole in my basement - but then the router noise might be be transmitted to the whole house!
Old 06-17-2009, 07:15 PM
TLHarrell is on a distinguished road
There are a couple mounts already made for the Fireball V90 cnc kit that will adapt a Colt router to that machine. You could easily pick one of them up and modify it or your Z axis plate to mate up.
Here's the link to the MCPI one: http://www.mcpii.com/Nicknacks.html
Old 06-18-2009, 06:38 PM
revwarguy's Avatar
accuracy Test movie
Here is an accuracy test movie on my new DIY CNC:
Old 06-18-2009, 06:45 PM
eloid is on a distinguished road
YouTube - My CNC Test 2
great job, nice machine...
you should excute it 100 time at ie 16 inch
then the last movement ie 101 times come back and touch it at 17
Old 06-20-2009, 12:34 PM
revwarguy's Avatar
Better test?
Thanks for the suggestion. I might actually have it do a whole complicated carve and then come back to home to see how far off it gets. Nevertheless, I was pretty happy with the outcome.
Old 06-20-2009, 09:43 PM
but it will be hard to know where you should be... if you move aknown distant
10 inch 20 x the move back to your cliper ie 11 inches
you will know how much your out...
  #11   Ban this user!
Old 06-21-2009, 03:19 PM
revwarguy's Avatar
Accuracy
Well, I just ran the same test as in the movie, but after it goes back the first time, it traced a 7X10 rectangle 100 times. When it moved back to the last corner, it returned to zero and there was still under a thousandth difference! I guess this says that any creeping errors are subtracting each other out?
  #12   Ban this user!
Old 06-21-2009, 08:15 PM
It means that your machine is VERY repeatable. I think the story will be complete when you cut out your first parts. There are some machines that are very repeatable, but not very accurate (they will cut things a little off, but they will do the same thing each time). I think yours will turn out to be both accurate and repeatable ...
Just thinking out loud here: I think the acid test for a machine like this would be to run a fine grid pattern of lines with the spindle turned off and a scribe needle in the collet. Scribe onto a sheet metal plate with dykem blue on it for contrast. The moire pattern generated should tell you how accurate the machine is ... I might try this myself if I ever get my machine completed
this thing is kicking my tail! llilrex PIC Programing / Design 4 06-07-2009 08:50 AM
Mostly ALIVE Smitty911 Benchtop Machines 4 11-15-2007 07:24 PM
k2cnc Macnine kicking out during jogging. Aksess Stepper Motors and Drives 7 06-05-2005 10:32 PM
Man Accused of Fatally Place-Kicking Dog WallCrawler CNCzone Club House 17 04-10-2004 04:18 PM
An idea i've been kicking around... NeoMoses General Metal Working Machines 6 06-01-2003 09:20 AM
