  #25   Ban this user!
Old 08-02-2009, 12:37 PM
Jack000 is on a distinguished road
if it was missing steps, the ending point of the gear probably wouldn't match the starting point, so that's probably not it. I think it's either backlash or lack of stiffness.
What happens when you pull/push on the bit, do you notice it moving slightly? That could explain the bad teeth. Not sure about the hole though, it seems pretty far off.
  #26   Ban this user!
Old 09-06-2009, 11:09 AM
Hamzter is on a distinguished road
Started designing a clock to build with my router, here's a test piece, an escapement wheel. About 15cm diameter, 6mm plywood, didn't realise the cut order had got messed up before cutting and so I'm missing one of the internal cutouts but it turned out pretty well. I need to recut it in some better wood though, the middle of the plywood is too weak and just crumbles when being cut very thin.
Took about 20 minutes to cut, which is a bit lengthy, mainly because I kept the cut depth and feed rates low to reduce flexing, which I measure as about +/-0.75mm on this one. I might try cranking up the spindle speed and feed rate on the next one, i'm getting bored with waiting...
ID:	88125   Click image for larger version
  #27   Ban this user!
Old 09-08-2009, 03:45 PM
Here's some shots of the clock design so far, lots to do yet, I've not yet decided where I'm going to mount the weight, might have to do some calcs to work out where's best, and I need to think about how I'm going to brace it all.
I'm not sure how I'm going to cut the text yet, I'd like to try do engraved style text with a 90 degree tip cutter (like grave stones), however I've no idea how I'd generate the G-Code for it at the moment. I was thinking I could do a swept 45 degree surface using some text as a path, the edge where the surfaces merge would effectively be my cutter path, but unfortunately I can't convince my CAD software to do it, it's not smart enough to deal with a self intersecting surface. Anyone got software/ideas on how I'd do that?
ID:	88337   Click image for larger version
  #28   Ban this user!
Old 09-10-2009, 12:48 PM
milhead's Avatar
milhead is on a distinguished road
The clock idea looks pretty slick!
Hi Hamzter;
As long as your machine accepts a standard g-code you can probably get somebody to generate you a v-carve toolpath from a .dxf file or something similar. Lots of folks in these forums own capable software.
Mil
...time spent working on hobbies is not deducted from your lifespan...
Last edited by milhead; 09-10-2009 at 12:48 PM. Reason: forgot clock complement...
Newbie - To build or not to build Router/Plasma Table dfranks CNC Plasma and Waterjet Machines 10 04-07-2011 11:16 PM
UK newbie first build in progress m2uk DIY-CNC Router Table Machines 7 01-19-2009 10:49 AM
Newbie wants to build a CNC Machine Pyros1988 DIY-CNC Router Table Machines 0 01-12-2009 04:47 PM
Newbie here! Want to build a small CNC rearwheels CNCzone Club House 2 11-15-2008 03:02 PM
