While I was wiring the motors in my new CNC Router machine, I noticed that the Gantry sides are not aligned properly to the table top; when the gantry is resting at the end of table stops, the right side touches the stop while the left side is off by ¼”. The table top is 36”x 48” I can fix this error but I would rather not spend the time if it is not critical or perhaps I can make adjustments with MACH3 to correct this misalignment Nicolas |
| If you leave it the way it is then when trying to cut a square/rectangle shape you will actually cut a rhombus (pushed over square/rectangle) Spend the effort to get it right and you won't regret it. Cheers M
__________________ No, Little-Johnny, pomegranate is not a type of English stone. |
| It may be that your frame is catywampus or not square. I would test the cut first to see if they come out square. Then adjust the gantry as needed to achieve perfectly square cuts. Circles could also suffer if it isn't cutting square.
__________________ Lee |
| Red dot alignment | Magritte | Laser Engraving & Cutting Machines | 17 | 03-08-2011 03:29 AM |
| SL-3H Turrent Alignment | TWyatt9 | Mori lathes | 2 | 03-17-2009 07:42 AM |
| need help with turret alignment | wonder | Calibration & Measurement | 0 | 07-25-2008 05:37 PM |
| Alignment | Megaplow | Syil Products | 11 | 03-20-2008 01:58 PM |
| tailstock (mis)alignment | ajbarrell | Shopmaster/Shoptask | 8 | 01-06-2007 11:18 PM |
