Old 06-08-2009, 04:58 PM
icecube is on a distinguished road
Stepperworld sp-3
Hello, I have a home brew cnc router that worked fine till just recently. The z axis will not move down while running a program. The axis moves with the jog keys ok. I have noticed there is no holding torque on the motor while a program is running. Hit the stop button in master5 and the motor holds. I swaped the z and y axis and the problem moved so I think I can rule out the motor. Any ideas as to where to begin? Here is a sample file I was using. Thanks in advance.
Old 06-08-2009, 05:43 PM
mwood3's Avatar
mwood3 is on a distinguished road
By this you mean the problem occurred on the Y axis after you swapped them and the Z axis was then working fine?
and what exactly did you swap on them? the motors, controllers, etc...?
http://www.g0704.blogspot.com/
Old 06-08-2009, 06:34 PM
I swapped the wiring from the sp-3 to the motors. After doing this then z had holding torque and y did not.
Old 06-09-2009, 06:18 AM
mwood3's Avatar
SP-3 is a type of controller? forgive me Im pretty new to steppers, I run a CNC machining shop for toyota, we use all Fanuc servo gear...
Old 06-09-2009, 08:54 AM
sp-3 is a stepper controller from stepperworld.com . Very low end but they do have some better products.
Old 06-09-2009, 10:23 PM
johnmac's Avatar
johnmac is on a distinguished road
If the stepper driver was bad, you would not be able to jog the axis. My thoughts are possible software corruption. Stepperworld has a utility program that lets you run up to 3 axis either single steps or steady running in either direction and varying speeds.
John
Old 06-10-2009, 05:56 AM
mwood3's Avatar
Im sure you have already done all the normal stuff..(checking cables, connections, etc...)
stepperworld drivers wjfiles Stepper Motors and Drives 1 06-04-2006 12:03 PM
Xylotex or stepperworld (or something else)? jdbaker Stepper Motors and Drives 3 12-16-2005 11:34 AM
help with stepperworld sp3/ht mmech General Electronics Discussion 9 10-24-2005 02:42 PM
Stepperworld fet 3 question Billw Stepper Motors and Drives 3 07-18-2005 02:03 AM
Stepperworld boards itsme Stepper Motors and Drives 2 02-09-2005 08:03 AM
