Old 06-05-2009, 07:19 AM
kolias is on a distinguished road
Home Limits
I’m to the point of installing the limit switches in my new machine.
What is the consensus regarding the Home switch for each axis. Do you need them or the MACH3 can do this and remember it once it’s set?
Old 06-05-2009, 08:33 AM
cdndave is on a distinguished road
Hey Nick
while Mach3 has the ability to set "soft" limits and home positions, for safety purposes, it is better to wire in physical switches. You can use 2 switches per axis, one acts as the home/limit while the other is just a limit.
Here is an example that uses 2 limit switches and a home (zero) switch for each axis, but I found it to be a fair example of how to wire the limit and home switches.
Are you still in design mode or are you actually building?
Dave
Old 06-05-2009, 08:44 AM
analogman is on a distinguished road
I have only limit switches.
Z axis - one switch for both + and -
Y axis - one switch for + and one for - wired in series
X axis - one switch for + and one for - wired in series
Mach3 nicely uses the limit switches for both home and limits. Works very well.
Yes mach3 will remember once home is set. You can press "ref all home" anytime you want and in will reset the location. Very easy to do.
Old 06-05-2009, 10:12 AM
pminmo's Avatar
pminmo is on a distinguished road
I only use one switch per axis for Home. Most software when it knows home can have a virtual set of limits. For steppers that is all that is needed. Servo's need limit switches. Home is more important to real work than limits. Some software can also use that one switch as both a home an limit switch.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
need help with limits and home switches eloid DIY-CNC Router Table Machines 4 04-28-2009 09:27 PM
limits and home sw eloid General Electronics Discussion 4 02-08-2009 06:42 PM
Home Limits Problems Cartierusm Mach Software (ArtSoft software) 11 09-08-2007 05:53 PM
home and limits Claude Boudreau DIY-CNC Router Table Machines 2 07-03-2007 03:46 PM
G-rex home and limits patrick71100 Gecko Drives 1 07-20-2006 06:17 AM
