#14
| I'm running a low cost, low pressure cooler as well. 5 gallon bucket, $12 (190 GPH) pump from Harbor Freight, and 50 ft of tubing (1/4" OD?). It's pretty small diameter stuff. I measured the flow and found it was only doing about 8 gal/hour. Somewhere I saw a recommendation for 20 gal/hour, but the spindle never seems to get warmer than about 72 degrees F. That includes some 2 hour jobs, but light cuts. Steve |
#15
| So I too have one of these spindles. 1.5kw little smaller. Works great. I heard somewhere that thought people were running these things to cool and the bearings were getting damaged. I know air cooled spindles have a warm up period and expect you to let it heat up to about 105 F before using, overwise you will take out the bearings. Can I assume the same should be true with the water cooled? I have a heater in a one gallon tank and leave a small pump running all the time. The spindle stays at 93 F and ready to go all the time without a warm up. I am not cutting heavy loads but the temp does rise to about 103F after a couple of hours. Do you have info on what they should run at? |
| New Machine Build- Water cooled spindle | i_am_fubar | General Metal Working Machines | 4 | 05-19-2009 11:25 AM |
| Need Help!- Water cooled spindle. | Mike F | General Metalwork Discussion | 12 | 04-13-2009 10:37 AM |
| cnclinx water cooled spindle | endgrainguy | DIY-CNC Router Table Machines | 3 | 09-25-2008 01:58 PM |
| Water cooled spindle need ??? | BFcarbon | Commercial CNC Wood Routers | 6 | 03-04-2006 03:05 PM |
| Is this spindle meant to be cooled with air or water? | Darc | DIY-CNC Router Table Machines | 2 | 10-22-2005 09:22 PM |
