Been reading this forum for a while before coming up with this. I want it for cutting aluminium and small sections of steel (slow cut rates are fine for this though). The table measurements are 700mm x 700mm. Am using 12x3 trapezoidal single start spindles and these rails and carriages: http://www.ondrives.com/products.asp?recid=227 Have tried to keep as many parts stock items, such as shaft supports etc. from this site: http://www.worldofcnc.com/main.asp It will be made from aluminium to keep weight down with the square bar being 30mm x 30mm retrofit frame: http://www.worldofcnc.com/main.asp?c...Retrofit+Frame For the electronics I was going with the hobbycnc pro driver board and 305oz-in 4.2V 3A stepper motors Whats peoples thoughts on this setup and any recomendations for a router. Am tempted by the Kress 530 / 800 / 1050 range but not sure if the spindle speed should be going slower for some of the metal work. Once I decide on the router I can finish off the z axis ![]() |
| Newbie - To build or not to build Router/Plasma Table | dfranks | CNC Plasma and Waterjet Machines | 10 | 04-08-2011 12:16 AM |
| New Large Table Build in Houston, TX (Build Log) | anitel | Plasma, EDM and other similar machine Project Log | 12 | 12-30-2008 03:45 AM |
| What project to build? | analogman | DIY-CNC Router Table Machines | 4 | 07-05-2008 08:41 PM |
| Servo motor build project... | WilliamD | General Electronics Discussion | 13 | 11-27-2006 02:35 PM |
