Old 06-01-2009, 01:45 PM
eloid is on a distinguished road
smooth stepper setup
I am almost ready to set up my pc and c23 breakout brd from cnc4pc
my questions are, How do I set up the smooth stepper with mach 3
there are no parallel port pins...so I am unclear what to do....
I will be ready in a few days... please advice...
this my frist cnc, unclear of the process for my 3 axis 2x2 table top cnc
thanks
Old 06-01-2009, 03:24 PM
Hirudin's Avatar
Hirudin is on a distinguished road
Sorry in advance if what I have to offer is stuff you've already covered... I don't own and have never used a SmoothStepper; I'm just trying to help.
Have you read the SmoothStepper manual?
http://warp9td.com/documentation.htm
It looks like there is a SmoothStepper driver for Mach3, have you installed it yet?
http://warp9td.com/downloads.htm
Old 06-04-2009, 07:06 AM
Kingjamez is on a distinguished road
The first thing you need to do is to install the Smoothstepper plugin into Mach. It is available from the warp9td.com website. Once you've done that Mach will bring a window up when you load it and ask if you want to use the smoothstepper or your parallel port. Choose smoothstepper.
The smooth stepper has the equivalent of 2 parallel ports on it, they are labeled as port 1 and port 2 on the PCB. I don't remember if the ribbon cable -> parallel port was included with the kit, but if not you'll need to buy one of these. Connect the ribbon cable to which ever port you choose to work from and then connect the other end to your breakout board.
You can now go into Mach and setup your "ports and pins" to map out what pin on your breakout board does what.
-Jim
Old 06-05-2009, 08:32 PM
Foxman is on a distinguished road
The smoothstepper is like having two remote parallel ports, connected via usb. Configure them just like parallel ports, the header->DB25 cable is wired exactly the same as a parallel port cable, just plug it into your breakout boards parallel connector.
Smooth stepper dnelso Industrial Hobbies (Support forum) 5 08-04-2009 12:07 PM
setting up smooth stepper eloid DIY-CNC Router Table Machines 1 04-24-2009 03:45 PM
What is a Smooth Stepper and ... gotfdirtball Mach Software (ArtSoft software) 1 03-16-2009 08:43 PM
best break out brd to use with smooth stepper brd markus_detroy DIY-CNC Router Table Machines 15 06-10-2008 07:14 AM
Smooth Stepper and resonance IQChallenged Machine Problems, Solutions , Wireless DNC, serial port 1 05-26-2008 08:30 PM
