Old 02-03-2005, 06:45 PM
kenbeth is on a distinguished road
Question Ball Bearing Size
Does anyone know the diameter of the ball bearing in a thk hsr 20
bearing block I have measured mine and have found one ball smaller
than the rest , as i have brought off ebay i am not sure if they have been replaced with a wrong size .
sizes measured are 3.969mm plus one at 3.175mm
Old 02-04-2005, 12:13 AM
Torsten's Avatar
Torsten is on a distinguished road
Just guessing but could it be that the smaller ball is
just used as a spacer.
May not be enough room for one of the proper size?
Ballscrew Basics Swede Linear and Rotary Motion 101 04-16-2012 08:09 PM
Ball bearing encoders - DIY? Mcgyver General Electronics Discussion 164 11-27-2005 12:25 PM
Ball screw angular contact bearing block dowling177 DIY-CNC Router Table Machines 0 03-15-2005 02:03 AM
strange bearing preload threads on ball screw mxpro32 Mechanical Calculations/Engineering Design 1 03-10-2005 08:07 PM
Ball Screws and machine size? swiftden DIY-CNC Router Table Machines 2 02-03-2005 04:02 PM
