Old 02-03-2005, 05:25 AM
swiftden's Avatar
swiftden is on a distinguished road
Ball Screws and machine size?
I phoned a few surplus machine stores locally today and was told that they had a table that was about 6ft by 3ft . which was for a router he said it had the x and y axis already but it was al manually operated. he stated that the bench was made out of aluminium . I'm thinking or looking at it tomorrow and was just wondering what size ball screws eg diameter and TPI would be needed over 6 feet . and same for 3 ft ?? also what size steppers
Old 02-03-2005, 06:04 AM
Mike F is on a distinguished road
For my router project the THK rep suggested 25mm for the X axis which is 2000mm long and 20 for the Y axis which is 600mm long. I think these sizes would probably suit your application too.
Table sounds interesting. Does it come with support? Keeping the thing absolutely flat once all the heavy gear is on top may be a problem.
Mike
Old 02-03-2005, 04:02 PM
swiftden's Avatar
not sure about the table yet but this place is a huge warehouse that strips old machine etc . i am going down there this afternoon with the trailer just in case it is ok and i buy it . the rep said they have a large quantity of stepper motors and ball screws etc so i will check it all out while im there . fingers crossed that it is ok. he mentioned that it is set up for vacum clamping so only time will tell wether it is any good for what i want.
Ballscrew Basics Swede Linear and Rotary Motion 101 04-16-2012 08:09 PM
Revolutionary Linear Drive System allanconway2 Polls 21 05-03-2009 08:27 PM
Which Ball Screws to use? Willyb Linear and Rotary Motion 4 01-19-2005 08:49 PM
Ball screws on eBay with no specs WoodSnarfer DIY-CNC Router Table Machines 10 11-15-2004 09:19 AM
Ball Screws for my machine CNC Brute DIY-CNC Router Table Machines 2 01-27-2004 03:11 PM
