  #13
Old 05-28-2009, 07:59 PM
ger21's Avatar
Better way is Homing/Limits, and check "Reverse".
  #14   Ban this user!
Old 05-28-2009, 08:26 PM
grahamshere is on a distinguished road
Thanks for all your help guys, AL check out the supplier you suggested, I need to get some longer nuts and bolts tomorrow. Graham
Old 05-28-2009, 08:52 PM
Al_The_Man's Avatar
Here is the product they supply.
http://www.heli-cal.com/cm/Home.html
  #16   Ban this user!
Old 05-28-2009, 11:42 PM
Thanks Al, which do you recommend ,#37? There's no price list, I found some on another site that were $40.00 each, hope there not that much. Graham
  #17   Ban this user!
Old 05-29-2009, 07:17 PM
Foxman is on a distinguished road
I thought that was just to change the direction the machine homes in. ???
Old 05-29-2009, 11:29 PM
ger21's Avatar
No. "Home Negative" changes the homing direction. "Reversed" changes the actual travel direction.
  #19   Ban this user!
Old 05-31-2009, 12:29 PM
well I think I found out what happen, let me tell ya I'm so po ed at myself. I was getting chatter when the router was heading in one direction but not the other, so any way I tightened z axis that is attached to the y and guess I did it to much, The bearings made a groove deep in to the rails, almost through. I didn't relies it was so tight, I'm surprised the bearings are not toast but there ok. had to replace the y rails,almost done, I'll see what else I can screw up. Graham
How to cut stepper motor shaft? harry11733 DIY-CNC Router Table Machines 3 07-25-2008 10:01 AM
Stepper motor with 6mm shaft? juzwuz Stepper Motors and Drives 6 03-23-2008 02:19 AM
Looking for a Coupling for 1/2" motor shaft to KR33 6mm shaft DonW DIY-CNC Router Table Machines 7 03-17-2008 03:58 PM
Stepper motor with 6mm shaft juzwuz Stepper Motors and Drives 4 01-16-2008 12:16 AM
DC Motor shaft wjfiles General Metalwork Discussion 2 08-09-2007 12:51 PM
