Old 05-28-2009, 05:07 PM
Robotics Guy is on a distinguished road
Small CNC machine for drilling PCBs
I'm going to build a small CNC machine to drill the PCBs I'm planning on making. I'm sure as I start building this that I'll have more questions, but right now I just have one.
For a *very* small low speed, low torque CNC machine what would be better:
1) Small DC motors with shaft encoders on them
or
2) Stepper motors
Thanks for the advice!
Old 05-28-2009, 06:27 PM
BobF is on a distinguished road
Steppers are easier to implement for DIY. They give no feedback, which is not near as big a deal as it may seem. There are many machines here that use steppers.
Old 05-29-2009, 01:17 AM
analogman is on a distinguished road
When I was looking at PCB milling, the fireball V90 sure had my eye.
http://www.fireballcnc.com/machines-...terceptor.html
Have you seen the site:
http://pminmo.com/millingpcbs/milledpcb.htm
Old 05-29-2009, 09:25 AM
Drools's Avatar
Drools is on a distinguished road
I started into this the exact same way, needing a something to drill and mill PCBs. I started reading and reading and....
Finially I decided if I'm in for a penny I might be in for a pound and make something I can do larger wood engraving with. I'm making a 2'x3' router which eventually I hope will be able to make the pieces for a smaller 12"x12" PCB mill. I think steppers should be just fine for what you have in mind.
You might find this link interesting.
http://hi.baidu.com/niejh/blog/item/...6562c84a0.html
Brent
Old 05-29-2009, 12:33 PM
Thanks for the links, I hadn't seen those websites.
I'm actually not planning on using this as a router at all. Essentially I just want an automated drill
I'm thinking about using some cheap NEMA 23 steppers, and I bought some super-cheap threaded rod yesterday at the hardware and I think it will actually work really well.
Old 05-29-2009, 01:54 PM
DarrenV is on a distinguished road
Hello Robotics Guy,
I have been working on a 4-axis controller for a pick and place machine. One of my design requirements was a simple drill for test fixtures, which is very close to your needs. The controller is 50v 3.5a per phase with USB or Parallel Port interface. I really wasn't designing this to sell, but I couldn't find any cheap alternatives so I had to design my own.
I was designing it for Nema 23 steppers, running open loop. I don't think the torque requirements for your drill would cause a Nema 23 stepper to lose steps.
The USB software isn't done yet(I can control the motors from software, but I don't have a parser for the drill or part files yet). But I brought out the step/direction signals to a header for Parallel Port control so others would be able to use existing software.
Anyway, since I assume if your drilling PCBs you must have at least a fundamental knowledge of electronics I would be happy to share my design with you, or if you want, I can sell you a finished version at cost ($40-$60), I haven't looked at the BOM costs in a while so I am not sure what my cost is.
Let me know if your interested in the design files
Darren Vandervort
darren@opencapitalist.org
Old 06-01-2009, 05:05 PM
Thanks for the offer Darren, but a big part of this project for me is the learning experience, so I think I'd prefer to make the electronics board myself.
I do appreciate the offer though.
Old 06-17-2009, 01:40 PM
I'm still trying to figure out the best way to build the X and Y axis. I need to use cheap materials, and so far these are the only two ways that I've been able to find:
Using steel rods:
http://www.engadget.com/2006/07/04/h...achine-part-2/
And,
Using aluminum U channels:
http://www.instructables.com/id/Easy...hine/?ALLSTEPS
It sure seems like both of those designs are going cause a lot of friction, and maybe binding, though. Any ideas on a better - but still cheap - way to do this?
Old 06-17-2009, 02:05 PM
jalessi's Avatar
jalessi is on a distinguished road
Post
Robotics Guy,
These are very inexpensive.
http://tinyurl.com/kllb2v
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 06-17-2009, 03:05 PM
Thanks for the link, but I'm not sure that those will be sturdy enough. All of the drawer slides I've seen also wiggle around a lot, which would be disastrous for a CNC machine :-)
  #11   Ban this user!
Old 06-17-2009, 03:11 PM
kvcummins's Avatar
kvcummins is on a distinguished road
Have you thought about using bearings on aluminum angle riding on aluminum angle?
Ken Cummins
Still looking for a Kaplan program for the Turing Test...
  #12   Ban this user!
Old 06-18-2009, 11:44 AM
Interesting.. That might work really well!
Newbie- Buying a new cnc machine just for making pcbs Dark-Angel DIY-CNC Router Table Machines 4 10-31-2008 10:54 PM
Aluminium Drilling - Small Bit Bryan GD General Metalwork Discussion 11 07-13-2008 11:34 PM
Low cost machine for PCBs, engraving, and small parts jdlinke Want To Buy...Need help! 2 01-27-2008 01:45 PM
introduce new 0.2mm small hole drilling EDM machine Robine Product Announcements & Manufacturer News 0 03-28-2007 04:14 AM
wich Machine can i buid to mill PCBs? samsagaz DIY-CNC Router Table Machines 20 05-23-2005 05:23 PM
