  #37   Ban this user!
Old 06-20-2009, 12:37 PM
pminmo's Avatar
pminmo is on a distinguished road
Originally Posted by Robotics Guy View Post
Do you think that soft brass on steel, would work better?
You would be better off with a plastic bearing/bushing such as Delrin of PTFE. http://www.mcmaster.com/#sleeve-bearings/=2efy95 2610T26 or 2639T26 and drill rod. Depending on length: http://www.use-enco.com/CGI/INSRIT?P...PARTPG=INLMK32
Drill rod is a higher polish than CRS and more precise in diameter. It's a pretty darn good precision shaft for the price. Bronze bearings do not work on drill rod or steel shafting well for the common DIY'er as there is no room for misalignment. Bronze bearings does work well on precision shafting as it's precision polished.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Newbie- Buying a new cnc machine just for making pcbs Dark-Angel DIY-CNC Router Table Machines 4 10-31-2008 09:54 PM
Aluminium Drilling - Small Bit Bryan GD General Metalwork Discussion 11 07-13-2008 10:34 PM
Low cost machine for PCBs, engraving, and small parts jdlinke Want To Buy...Need help! 2 01-27-2008 12:45 PM
introduce new 0.2mm small hole drilling EDM machine Robine Product Announcements & Manufacturer News 0 03-28-2007 03:14 AM
wich Machine can i buid to mill PCBs? samsagaz DIY-CNC Router Table Machines 20 05-23-2005 04:23 PM
