I am milling some .080 aluminum sheet with a large number of thru holes range in size from .125 to 1.0. A couple of questions: (1) should I just use a .125 end mill for all operations? (2) for the .125 holes, is it better that I change tools to a drill, or can I use a end mill OK? (3) for the large holes, can I just do an inside profile, leaving behind a little disc, or is it better to do like a pocket and mill out all the material - these are all thru holes. thanks for the help! AM |
| It needs to be a center cutting end mill since at least for the .125 it is a plunge cut completely. Set the plunge speed low. If you cut an inside profile, and leave a disk, you will launch the disk unless there is something holding it down. Look at the Onsrud cutter site for feeds and speeds in aluminum. |
| T slot tool post with drill bit tool holder | brucesu1 | CNC Tooling | 0 | 06-09-2008 06:04 AM |
| Very slow tool change on Tool Room Mill | Capt Crunch | Haas Mills | 3 | 12-21-2007 01:20 PM |
| G43.1 - Tool Axis Direction Tool Length Compensatioin | EngTech | Mazak, Mitsubishi, Mazatrol | 8 | 12-06-2007 05:01 AM |
| Pocketing and tool sizes | jderou | BobCad-Cam | 1 | 08-31-2004 02:26 PM |
| NewB Q. Tool sizes | Rhodan | G-Code Programing | 2 | 05-20-2004 11:05 AM |
